November 7, 2020, 08:27 |
SuperCritical Fluid modeling
faezeh
Hello every body!
I am going to model a supercritical fluid inside a pipe.As the thermodynamic properties such as density varies with temp and pressure ,I wrote UDF for properties. my question is: 1.During writing udf for specific heat, as the specific heat is dependent to temp and pressure for calculating (((*h))) integral from T_ref to T is required or it is calculated through c_p*(T-T_ref)? 2. writing udf for turbulent viscosity,how can I call written udf for density to calculate turbulent viscosity(in DEFINE TURBULENT VISCOSITY)? thanks for helping me |
November 8, 2020, 15:43 |
Refik
Rep Power: 12 |
1. Could you please explain your question a bit more clearer? Basically you have to calculate departure functions and add it to reference cp value.
2. Im assuming this is for FLUENT. You do not have to do anything for "turbulent viscosity". You have to write an UDF for laminar viscosity which will be utilized in viscosity calculation along with turbulent viscosity. Also thermal conductivity should be modeled. I can help further if you need. Refik |
Modeling carbon nanotube as particle in fluid | terktor | FLUENT | 0 | January 1, 2016 18:54 |
One inlet with the different types of fluid in Lake\River Modeling | ramakant | Main CFD Forum | 0 | March 16, 2015 03:09 |
Modeling Solid and Fluid at the same using Interface BC..Help needed | Prince Jassal | Main CFD Forum | 1 | June 12, 2013 06:07 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Modeling of Particles in Non-Newtonian Fluid | arien009 | CFX | 3 | May 15, 2011 19:53 |
