November 6, 2020, 22:22 |
setting of UDS
Rep Power: 6 |
If I don't need to set boundary values in some places, do I just keep the default setting which is "Specified Flux equals zero"?
November 9, 2020, 01:12 |
Alexander
Rep Power: 34 |
fast answer is yes.
however, the real answer comes from concept of the model you are going to simulate. Actually, you should know from the very begging what are boundary conditions in your model
best regards ****************************** press LIKE if this message was helpful |
uds |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 23:38 |
setting UDS Flux | Andrew Garrard | FLUENT | 9 | February 10, 2015 14:26 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
