UDF error in Fluent
Old   October 29, 2020, 06:39
Default UDF error in Fluent
Vikash Vashisth
vikasche.engg@gmail.com is on a distinguished road
The following error has been pop-up while compiling the UDF for population balance modeling
# Generating udf_names.c because of makefile pdf.obj
udf_names.c
udf_names.c(8): error C2065: 'break_up_pdf_par': undeclared identifier
udf_names.c(8): warning C4312: 'type cast': conversion from 'int' to 'void (*)(void)' of greater size
udf_names.c(8): error C2065: 'UDF_TYPE_PB_BREAKUP_RATE_PDF': undeclared identifier
udf_names.c(8): error C2099: initializer is not a constant
The UDF code is
UDF that computes the particle breakage frequency
#include "udf.h"
#include "sg_pb.h"
#include "sg_mphase.h"
DEFINE_PB_BREAKUP_RATE_FREQ(break_up_pdf_par, cell, thread, d_1)
real epsi, alpha, f1, f2, rho_d;
real C1 = 0.00481, C2 = 0.08, sigma = 0.07;
epsi = 0.5;
alpha = 0.12;
rho_d = 1000.;
f1 = pow(epsi, 1./3.)/((1.+epsi)*pow(d_1, 2./3.));
f2 = -(C2*sigma*(1.+epsi)*(1.+epsi))/(rho_d*pow(epsi,2./3.)*pow(d_1, 5./3.));
return C1*f1*exp(f2);
Please help
vikasche.engg@gmail.com is offline   Reply With Quote
Old   October 29, 2020, 08:14
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
well, there is a list of problems... fix them
if you have no idea how, share your code, so people here will try to help you
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
pbm model udf, udf compilation
Problem running fluent with udf on batch tobi b. Fluent UDF and Scheme Programming 3 April 14, 2016 14:54
implementing UDF for fluent in workbench for running multiple simulations faizan_habib7 Fluent UDF and Scheme Programming 0 March 18, 2016 23:29
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 11:16
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 11:57
