How to read a Value from Text File and store it in Variables
Old   October 26, 2020, 03:45
Default How to read a Value from Text File and store it in Variables
Amirreza Niazmehr
Amirreza_pro is on a distinguished road
Hi guys
This is my text file (Data.txt):
rho_0 10
kp_0 8
Beta_kp 6
x_min 5
x_max 8
y_min 9
y_max 5
z_min 4
z_max 7
I want to read from this text file line by line and store each Value in the parameter at the same line. for example, for the first line store 10 in rho_0. I have written as below.At the next end I want to use x_min and x_max ... to calculate Volume. I mean
Volume=(x_max-x_min)*(y_max-y_min)*(z_max-z_min).
I have written this code (as below) in C and now I want to use it in my UDF.
First I want to define the Macros and then use this code.
I just want to know if my code works, if I first use and define the proper Macros. I mean,is the body of my code proper for using in UDF?
#include <stdio.h>
#include <math.h>
#include <stdlib.h>
int main()
    double rho_0, kp_0, Beta_kp;
    double x_min, x_max ,y_min ,y_max ,z_min, z_max, V_plasmazone;
	char param_name[100];
    FILE *inputfile;
    /*char inputpath[100];
    char path [100] ;
    strcpy(inputpath, path);
    strcat(inputpath, "Data.txt");
    inputfile = fopen(inputpath, "r");
    if(inputfile)
        ScanCheck(fscanf(inputfile, "%s", inputpath), 1, inputfile, "Data.txt", 1);
        strcat(path, inputpath);
        strcat(path, "/");
    else
        Error("Error opening input.txt - file!");
  inputfile =fopen ("Data.txt","r") ;
    if(inputfile == NULL) {
               perror("Unable to open file!");
               exit (1);
   fscanf(inputfile, "%s %lf\n", param_name, &rho_0);
   printf("%s %lf\n", param_name, rho_0);
   fscanf(inputfile, "%s %lf\n", param_name, &kp_0);
   printf("%s %lf\n", param_name, kp_0);
   fscanf(inputfile, "%s %lf\n", param_name, &Beta_kp);
   printf("%s %lf\n", param_name, Beta_kp);
   fscanf(inputfile, "%s %lf\n", param_name, &x_min);
   printf("%s %f\n", param_name, x_min);
   fscanf(inputfile, "%s %lf\n", param_name, &x_max);
   printf("%s %f\n", param_name, x_max) ;
   fscanf(inputfile, "%s %lf\n", param_name, &y_min);
   printf("%s %f\n", param_name, y_min);
   fscanf(inputfile, "%s %lf\n", param_name, &y_max);
   printf("%s %f\n", param_name, y_max);
   fscanf(inputfile, "%s %lf\n", param_name, &z_min);
   printf("%s %f\n", param_name, z_min);
   fscanf(inputfile, "%s %lf\n", param_name, &z_max);
   printf("%s %f\n", param_name, z_max);
 V_plasmazone = ( x_max - x_min )*( y_max - y_min )*( z_max - z_min );
 printf( "V_plasmazone %lf\n", V_plasmazone );
              fclose(inputfile);
              return 0;
Amirreza_pro is offline   Reply With Quote
Old   October 26, 2020, 09:40
pakk will become famous soon enough
To use it in Fluent, you should not make it main(), but use a Fluent Macro. Probably EXECUTE_ON_DEMAND is appropriate here; you can then tell Fluent to execute this code whenever you want (look in help to find out how if you don't know yet).
pakk is offline   Reply With Quote
Old   October 29, 2020, 08:00
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I agree with Pakk, you do propably want to use execute on demand macro
read Ansys Fluent Customization manual for good examples
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 29, 2020, 10:24
Amirreza Niazmehr
Thanks alot guys for your help
Old   February 16, 2024, 18:20
Default problem with read file
amina
aminalaouti is on a distinguished road
hi everyone ,
I want to know if my data file (containing 20,000 values) is being read by the udf. To do this, I've created a small program that reads the data from the data.txt file and prints it to another file (data1.txt).
My program compiles well, the library is created and I've hooked my udf to execute on demand.
The data.txt file contains 4 values:
0.2
0.2
0.1
0.1
results on file data1.txt are :
0.000 0.000 0.000 0.000
????????? where is the problem????
this is my udf:
#include "udf.h"
double coef[4];
DEFINE_ON_DEMAND(lire)
FILE* rfile;
FILE* rfile1;
rfile = fopen("C:\\Codes\\data.txt", "r");
rfile1 = fopen("C:\\Codes\\data1.txt", "w");
int i;
i = 0;
for (i = 0; i <4; i++)
fscanf(rfile, "%f", &coef[i]);
fprintf(rfile1, "%f", coef[i]);
fclose(rfile);
fclose(rfile1);
aminalaouti is offline   Reply With Quote
Old   April 5, 2024, 16:14
Dilz is on a distinguished road
Hey, I have the exact same problem. I get zeros when I compile and view the output. Did you resolve this?
Any help is appreciated,
Thanks
Dilz is offline   Reply With Quote
[swak4Foam] How to define boundary condition variables by using previosly defined variables? pawlo OpenFOAM Community Contributions 8 September 13, 2020 12:37
Shape optimization doesn't converge - Adjoint log file JPBLourenco SU2 Shape Design 0 December 11, 2017 09:41
Journal command for multiple case file read, and store data of static pressure along Ash Kot ANSYS 3 July 10, 2017 04:08
UDF macro to read the name of the case file polaritus Fluent UDF and Scheme Programming 2 March 23, 2015 05:59
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
