Distinguish particles injected from Injection
Old   October 23, 2020, 13:17
Post Distinguish particles injected from Injection
L.A.Isanka
Achini is on a distinguished road
Hello!
I'm working on a model to separate microparticles based on dipole interaction forces. Heterogeneous microspheres are injected using 2 injections, injection 0 & injection 1.
Do you know of a method to distinguish between particles injected from these injections. Injected particles from both injections are identical except for their surface properties and I'm using dipole interactions to separate the particles injected via the two injections. The interaction force is different for the two injections.
Thus, once a particle is located, I want to identify whether it is from injection 0 or injection 1.
Cant use DEFINE_DPM_INJECTION_INIT macro since I'm using DPM_BODYFORCE macro and cant insert DEFINE_DPM_INJECTION_INIT macro inside that.
I'd be grateful if you could help me with this.
Thank you!
Achini is offline   Reply With Quote
dpm in fluent, fluent udf, injection, interactions
how to determine the number of particles injected. welch FLUENT 2 January 18, 2024 05:08
Fluent UDF - Distinguish particles from two different injections Achini Main CFD Forum 0 October 12, 2020 12:02
file injection.: continuity fail; volume injection.: wrong total mass blerli_91 Fluent Multiphase 6 October 2, 2018 06:34
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 22:33
injection problem Mark New FLUENT 0 August 4, 2013 02:30
