I have two single udf files(see attachments), how can I put them together in one .c f |
October 22, 2020, 23:30 |
#21 |
Rep Power: 27 |
I see no reason why it works separately but not together. Please check if you attached heat_cf to the correct boundary. I suspect there is something in your setup that you are not telling us.
UDF compiling error | Weiqiang Liu | FLUENT | 2 | November 21, 2018 10:36 |
Single v.s. double precision | Confused | CFX | 15 | November 10, 2016 05:42 |
using define mass transfer udf for cavitation | Komon | Fluent UDF and Scheme Programming | 14 | June 21, 2016 03:50 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 01:53 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
