Fluent Post-Process UDF File
Old   September 25, 2020, 12:04
Default Fluent Post-Process UDF File
Ataberk
berkozaydin is on a distinguished road
I want to make a UDF file to prepare some contours and pathlines. And the UDF file contains the file path. I mean, when I import the udf file in ANSYS Fluent, it will prepare all contours and pathlines in a file that is located on my desktop. How can I implement this stuff in a code basically?
Thanks!
berkozaydin is offline   Reply With Quote
Old   October 5, 2020, 03:51
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
first of all, what exactly you want is unclear
everything you can do in GUI can be made using TUI commands (commands in fluent console)
for post processing you need scheme commands + TUI
UDF is used to control the solution, read/write data
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
fluent - udf, udf compile
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
