UDF for saturation temperature for Lee's Condensation model
Old   September 22, 2020, 10:28
Default UDF for saturation temperature for Lee's Condensation model
Chun Wheng
Boo85 is on a distinguished road
Hello everyone!
I am doing a fluent simulation for the condensation of water vapor on a cool surface exposed to air. So right now I am planning the simulation and would like some idea on how to write the UDF, as I think a UDF is needed to adjust the saturation temp based on the air moisture in the air above it.
The idea I have is to use VOF with 2 phases:
  1. Air phase with species transport (air and water vapor)
  2. Liquid water for the condensation of water
The objective is to use the UDF for calculate the saturated air temperature from ONLY the air phase assuming that is the primary phase. Therefore the UDF should not perform any calculations on the liquid water phase.
The UDF I found on the other thread, which I modified is this:
#include "udf.h"
#define rho_dry_air 1.2
#define rho_wv 0.59
DEFINE_PROPERTY(saturation_temperature,c,thread)
Thread *t_air = THREAD_SUB_THREAD(thread,0);
real mass_dry_air = C_YI(c,t_air,0)*rho_dry_air;
real mass_wv = C_YI(c,t_air,1)*rho_wv;
if (mass_dry_air>0) {
w = mass_wv / mass_dry_air;
return w*(XXXXXXXXXXXXXXXXXXXXXXXXXXXXX);
} else {
return 1000;
So with the humidity ratio, w, I will calculate the saturated air temperature under the return function. Most importantly will the UDF be able to achieve the calculation of just the air phase this way or am I totally off?
I have done very simple UDFs before like for the profile etc. This is my first UDF working with VOF, multiple species and using thread_sub_thread, so i am wondering if I am on the right track.
Any comments will be greatly appreciated! Thanks!
Boo85 is offline   Reply With Quote
Old   August 21, 2021, 17:05
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by Boo85 View Post
Hello everyone!
#include "udf.h"
#define rho_wv 0.59
} else {
return 1000;
Were you able to find out solution of your problem?
Far is offline   Reply With Quote
UDF saturation temperature (evaporation model Fluent) bbarbier07 Fluent UDF and Scheme Programming 12 March 14, 2024 08:29
primary/secondary phase in VoF condensation model soumitra2102 FLUENT 2 December 16, 2019 11:41
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 21:21
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
