writing udf for fluid properties which are polynomial variation of temperature
Old   September 20, 2020, 09:20
Default writing udf for fluid properties which are polynomial variation of temperature
ranjith
ranjith prakash is on a distinguished road
I am doing a project on cfd analysis of ejector in a ejector-refrigeration system. There are two inlet and one outlet. the fluids are refrigerant vapour. from the papers it is mentioned that the density, thermal conductivity and other properties are polynomial variations of temperature and udf needs to be added. how to give udf for this?
ranjith prakash is offline   Reply With Quote
Old   September 20, 2020, 10:33
Post
mohammad
movaffagh is on a distinguished road
hi body,
you can set your polynomial's coefficints in material section.
movaffagh is offline   Reply With Quote
Old   September 20, 2020, 11:31
ranjith
Originally Posted by movaffagh View Post
hi body,
Thanks for the reply but I couldn't see the variation equation in those papers. Actually from Refprop software we can take the properties According to the pressure and temperature but without udf how ansys is able to know the variation of fluid properties with temperature. For me the boundary conditions are pressures.
Old   September 20, 2020, 17:23
Smile
mohammad
the bc is not important. when you want to give property of material in ansys fluent, you have more option like: constant,linear,polynomial,pieswise and ...
and you can give your property depend on temp.
ejector, polynoamial variation, udf
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
UDF to get the average temperature of a face and use it to define a property gdb Fluent UDF and Scheme Programming 19 November 3, 2022 04:11
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Gas PROPERTY in function of TEMPERATURE and PRESSURE (UDF) Captain Convergence Fluent UDF and Scheme Programming 12 March 2, 2020 13:24
UDF temperature variation Alex E-H FLUENT 3 February 19, 2017 15:55
