1way FSI - Wall position
Old   September 14, 2020, 02:52
Exclamation 1way FSI - Wall position
billyCFD is on a distinguished road
Hello, I have a problem regarding a situation that apparently seems simple but I have difficulty in solving.
I'm analyzing the deflation of a cubic component made of rubber. It can be seen as the deflating of a balloon: at time 0 the cube has a certain volume and internal pressure. This pressure decreases and with it also the volume until the internal pressure is equal to the external one.
The initial idea was to make a 2-way FSI but the resources it requires are too high (RAM, etc ...) so I had to fall back on a kind of 1-way FSI.
The idea is to get the volume of my cube as a function of pressure from Mechanical, which I did, and use this relationship in Fluent. In this way I can take into account the volume variation that inevitably affects the deflation process.
Since the geometry can be considered cubic, it would be enough for me to move a wall to simulate the change in volume as in a piston.
I wrote a UDF that relates the internal pressure with the size of the cube and the time to obtain a speed to be applied to a wall, unfortunately, this approach does not work due to instability problems.
The thing I would like to try is to assign a position to a wall of my cube as a function of pressure across a UDF.
The question is: what can I use as a UDF to define the position (say the height Y of my wall) as a function of the internal pressure? There is a simple way to assign a position (that change in time) to a wall?
billyCFD is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
FSI and Wall Compression ashtonJ CFX 2 November 6, 2015 17:33
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
