cc: command not found fluent, linux
Old   September 11, 2020, 02:56
Default cc: command not found fluent, linux
Ajinkya S
Aj_45 is on a distinguished road
I am trying to compile following udf for fluent 15.0 on linux system
#include "udf.h"
real velx = 0.0;
DEFINE_CG_MOTION(box, dt, vel, omega, time, dtime)
        NV_S(vel, =, 0.0);
        NV_S(omega, =, 0.0);
        velx = 0.05 * sin(3.1415927 * time / 10);
        vel[0] = velx;
But I get the following error:
# Compiling grid_motion.o because of grid_motion.c
cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= -I/export/apps/ansys_inc/v150/fluent/fluent15.0.0/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/export/apps/ansys_inc/v150/fluent/fluent15.0.0/src -I/export/apps/ansys_inc/v150/fluent/fluent15.0.0/cortex/src -I/export/apps/ansys_inc/v150/fluent/fluent15.0.0/client/src -I/export/apps/ansys_inc/v150/fluent/fluent15.0.0/tgrid/src -I/export/apps/ansys_inc/v150/fluent/fluent15.0.0/multiport/src -I/export/apps/ansys_inc/v150/fluent/fluent15.0.0/multiport/mpi_wrapper/include -I/export/apps/ansys_inc/v150/fluent/fluent15.0.0/multiport/mpi_wrapper/src -I. -c grid_motion.c
/bin/sh: cc: command not found
make[3]: *** [grid_motion.o] Error 127
make[3]: Target `libudf.so' not remade because of errors.
make[3]: Leaving directory `/home/ajinkya/aj/mesh_motion/libudf/lnamd64/2ddp'
make[2]: *** [lnamd64] Error 2
make[2]: Leaving directory `/home/ajinkya/aj/mesh_motion/libudf/lnamd64/2ddp'
make[1]: *** [default] Error 2
make[1]: Leaving directory `/home/ajinkya/aj/mesh_motion/libudf/lnamd64/2ddp'
A similar thread for cc: command not found, on the forum suggest installing the gcc compiler but I guess I have it installed already.
which gcc returns: /usr/local/bin/gcc
which cc returns: no cc in (...)
I am compiling the udf in gui using (Define-User defined-Functions-Compiled) and then adding the source file followed by clicking the 'build' option.
What could be the problem here?
Thanks,
Ajinkya
Aj_45 is offline   Reply With Quote
Old   September 16, 2020, 09:38
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may try to compile from terminal, but you should create make file first.
For more information about that check Ansys Fluent Customization manual
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
fluent - udf
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 16:11
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 17:16
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
