UDF Not Returning Value
Old   August 12, 2020, 12:58
Default UDF Not Returning Value
David
David12 is on a distinguished road
Hello everybody, I'm having trouble with my UDF that uses the macro DEFINE_TRANSIENT_PROFILE. I am using this code in order to rotate a propeller in ANSYS, and therefore I use the UDF in the cell zone condition for frame motion and rotational velocity. The UDF uploads with no warnings; however, the Report Definition for the UDF shows 0 on both the plot and the print console. Could somebody point out to me what I'm doing wrong? Thank you!
**Note, I took out some code and put it in comments to check whether or not that was the problem and it wasnt
File Type: c RPM UDF.c (422 Bytes, 7 views)
David12 is offline   Reply With Quote
Old   August 12, 2020, 23:29
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
code should work with no problem
what is Report Definition ?
are you sure, you are hooking profile properly?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
