udf for spatial and temporal profile - linking error
Old   August 6, 2020, 18:08
Question udf for spatial and temporal profile - linking error
Alexandre M S Costa
amscosta is on a distinguished road
Hi All,
Hopefully some udf guru can tell what is wrong. The udf is pretty useful.
I am trying to compile the UDF below but I am facing the following link error message:
kernel32.lib(KERNEL32.dll) : error LNK2005: ReadFile already defined in temporalprof.obj
Creating library libudf.lib and object libudf.exp
libudf.dll : fatal error LNK1169: one or more multiply defined symbols found
The UDF below reads in a text file that contains data for both spatial and temporal variation of a scalar quantity.
The format of text file:
- The first line contains the NPtsTm (number of time steps points) and
NPtsData (number of data points)
- Next line is a blank
- Next NPtsTm lines contain the time data
- Next NPtsData lines contain the x-coordinates data
- Next NPtsData lines contain the y-coordinates data
- Next NPtsData lines contain the z-coordinates data
- Next NptsData lines contain the first scalar data at time#0
- Next NptsData lines contain the first scalar data at time#1
- ... so on ... until the last time data is given
The UDF code :
#include "udf.h"
int NPtsTm,NPtsData;
int DataIsRead = 0;
real *tmarr,*xarr,*yarr,*zarr,**Tarr;
DEFINE_ON_DEMAND(ReadFile)
int n,i;
float data;
FILE* fp;
fp = fopen("DataFile","r");
if ( fp!=NULL )
Message("Reading file \n");
else
Message("Error in opening file \n");
fscanf(fp,"%d %d\n",&NPtsTm,&NPtsData);
Message("\n");
Message("There are %d time entries and %d spatial entries\n",NPtsTm,NPtsData);
/* Dynamic allocation for 1D array */
tmarr = (real *) malloc(NPtsTm*sizeof(real));
xarr = (real *) malloc(NPtsData*sizeof(real));
yarr = (real *) malloc(NPtsData*sizeof(real));
zarr = (real *) malloc(NPtsData*sizeof(real));
/* Dynamic allocation for 2D array */
real *temp;
temp = (real * ) malloc(NPtsTm*NPtsData*sizeof(real));
Tarr = (real **) malloc(NPtsTm*sizeof(real *));
for(n=0;n<NPtsTm;n++)
Tarr[n] = temp + n*NPtsData;
if ( (tmarr==NULL)||(xarr==NULL)||(yarr==NULL)||(zarr== NULL)||(Tarr==NULL) )
Message("Memory allocation error \n");
fscanf(fp,"\n");
Message("\n");
Message("The following is the %d time entries\n",NPtsTm);
for ( n=0;n<NPtsTm;n++ )
fscanf(fp,"%f \n",&data);
tmarr[n] = (real)data;
Message(" %f\n",data);
fscanf(fp,"\n");
for ( i=0;i<NPtsData;i++ )
xarr[i] = (real)data;
fscanf(fp,"\n");
yarr[i] = (real)data;
fscanf(fp,"\n");
zarr[i] = (real)data;
fscanf(fp,"\n");
Tarr[n][i] = (real)data;
DataIsRead = 1;
fclose(fp);
/* Output check */
Message("\n");
Message("The following is the %d coordinate entries\n",NPtsData);
Message(" %f %f %f\n",xarr[i],yarr[i],zarr[i]);
Message("\n");
Message("The following is scalar data for time entry # %d\n",n);
Message(" %f\n",Tarr[n][i]);
real GetData(real xf, real yf, real zf, real tm)
int n,nL,nU,i;
real tmL,tmU,data,dataL,dataU,sf,smin;
tm += 1.0e-7;
/* Find the time bracket */
nL = 0;
nU = 1;
tmL = tmarr[nL];
tmU = tmarr[nU];
if ( (tm>=tmarr[n])&&(tm<=tmarr[n+1]) )
nL = n;
nU = n+1;
tmL = tmarr[nL];
tmU = tmarr[nU];
break;
/* Find data at the lower and upper time bound */
smin = 1.0e30;
dataL = 0.0;
dataU = 0.0;
sf = sqrt( pow((xarr[i]-xf),2) + pow((yarr[i]-yf),2) + pow((zarr[i]-zf),2) );
if ( sf<=smin )
smin = sf;
dataL = Tarr[nL][i];
dataU = Tarr[nU][i];
/* Interpolate between lower and upper time values */
data = dataL + ( tm - tmL )/( tmU - tmL )*( dataU - dataL );
return data;
DEFINE_PROFILE(Tspec,tf,pos)
face_t f;
real tm,xf[ND_ND];
tm = RP_Get_Real("flow-time");
begin_f_loop(f,tf)
F_CENTROID(xf,f,tf);
F_PROFILE(f,tf,pos) = GetData(xf[0],xf[1],xf[2],tm);
end_f_loop(f,tf)
amscosta is offline   Reply With Quote
Old   August 7, 2020, 06:11
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
change in
ReadFile to any other name, for example ReadFile1
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 7, 2020, 12:45
Alexandre M S Costa
Great . Thank you very much.
Old   July 6, 2021, 05:11
Default Problem with using the code
Farshad Taj
@Farshad_Taj is on a distinguished road
Originally Posted by amscosta View Post
Hi All,
The UDF code :
#include "udf.h"
int DataIsRead = 0;
int n,i;
float data;
FILE* fp;
if ( fp!=NULL )
else
Message("\n");
real *temp;
fscanf(fp,"\n");
Message("\n");
fscanf(fp,"\n");
fscanf(fp,"\n");
fscanf(fp,"\n");
fscanf(fp,"\n");
DataIsRead = 1;
fclose(fp);
/* Output check */
Message("\n");
Message("\n");
int n,nL,nU,i;
tm += 1.0e-7;
nL = 0;
nU = 1;
tmL = tmarr[nL];
tmU = tmarr[nU];
nL = n;
nU = n+1;
tmL = tmarr[nL];
tmU = tmarr[nU];
break;
smin = 1.0e30;
dataL = 0.0;
dataU = 0.0;
if ( sf<=smin )
smin = sf;
return data;
face_t f;
real tm,xf[ND_ND];
begin_f_loop(f,tf)
end_f_loop(f,tf)
Hi amscosta,
I hope you are doing well. I am trying to use the UDF you have provided to have a Spatio-temporal velocity profile. I could successfully compile this code in Fluent, but when I try to initialize my solution, the following error appears on my screen and then, fluent is crashed.
Error: MPI Application rank 0 exited before MPI finalization() with status 2
I would be thankful if you could let me know whether you had this error or not, and the potential way you used to deal with that.
Also, I would be thankful if you could provide me with a sample of the text file that is being used for this UDF. Using the sample, I would understand whether I have written my text file in the correct format or not.
Best,
Farshad
@Farshad_Taj is offline   Reply With Quote
spatial temporal profile
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 17:35
Using a Mass Flow Rate profile with a Temporal field as a Boundary Condition Jotheman Main CFD Forum 0 October 18, 2015 10:25
Temporal and spatially varying temperature udf avi@lpsc Fluent UDF and Scheme Programming 0 August 24, 2013 06:43
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 19:00
temporal error for unsteady flow hawk Main CFD Forum 8 August 25, 2006 07:58
