Inlet compositions manipulations using UDF
Old   August 4, 2020, 01:43
Default Inlet compositions manipulations using UDF
Khan
Khan_CFD is on a distinguished road
In my research problem, I need to add the contents of outlet of a reactor (say cylindrical one) to the inlet stream. For this purpose, I need to add mass flow rates of each species coming out of the reactor to those already going into the reactor, at the inlet face.
Please suggest if it is possible to do it with the use of UDF and how?
Thanks and regards.
Khan_CFD is offline   Reply With Quote
Using input parameters (velocity inlet) in UDFs - bad UDF? student_1994 Fluent UDF and Scheme Programming 6 September 14, 2018 21:31
UDF problem- time dependent temperature at inlet kaeran FLUENT 1 June 16, 2015 22:48
UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t" jpina FLUENT 10 April 11, 2015 15:19
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
Setting Inlet as Wall until flow occurs via UDF emmkell Fluent UDF and Scheme Programming 0 May 1, 2012 13:05
