Matching boundary values for slit face zones
Old   July 29, 2020, 04:10
Default Matching boundary values for slit face zones
ShOh
Shoh is on a distinguished road
Hello, I would really appreciate if you could give me an answer.
Inside the computational domain, I have a face at which velocity in x direction is 3 m/s. Also, I have to solve passive scalar field, and the scalar boundary condition at the face should be zero flux.
Since the face has 2 adjacent cell zones, I first set the face to 'wall' and then 'slit' the face into 2 uncoupled wall zones. Next, I change both two 'wall's to 'velocity-inlet', and impose the velocity of 3 m/s in the x direction for both walls. As done for the velocity, I also impose the zero flux boundary condition for the scalar at both walls.
As a result, the fluid seems to 'continuously' flow through the walls, but the problem is the scalar field is not continuous.
So, my question is how can I match the scalar distribution at both walls.
Shoh is offline   Reply With Quote
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
Simulating fire in a tunnel luca1992 OpenFOAM 14 August 16, 2017 14:50
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
