how to distinguish different injections in UDF
Old   July 2, 2020, 04:52
Lightbulb how to distinguish different injections in UDF
Yang Yaji
yyj-sy is on a distinguished road
Hello,all!
I want to consult how to distinguish DPM injections in UDF programming. I am modeling underwater oil/gas leakage with DPM and I set two injections in DPM for oil and gas respectively.
I write a macro to define gas bubble sizes in DEFINE_EXECUTE_AT_END. Now I want this macro to work only on gas particles when called by FLUENT, but I don’t know how to code to distinguish oil particles and gas particles.
Thank you!
yyj-sy is offline   Reply With Quote
Old   October 12, 2020, 10:18
Default I have the same question
L.A.Isanka
Achini is on a distinguished road
I'm using two injections to define carbon microspheres with different surface groups. And I need to find a method to separate the two injections separately.
Did you find a way to distinguish them?
Thanks in advance!
Achini
Achini is offline   Reply With Quote
Old   November 24, 2022, 05:23
Default the marco about the initial values of the particle may help
liuhanwen
liuhanwen is on a distinguished road
Hi, maybe you can loop all the injections and particles first, and using the macros below to identify if the particle belongs to the injections you want to handle. The values These macros return are the initial values of the particles. And the beginning of the macro may be 'TP' or 'P', I am not sure about the difference.
Tracked_Particle position i= 0, 1, 2
TP_INIT_POS(tp)[i]
Tracked_Particle velocity i= 0, 1, 2
TP_INIT_VEL(tp)[i]
Tracked_Particle diameter
TP_INIT_DIAM(tp)
Tracked_Particle temperature
TP_INIT_TEMP(tp)
Tracked_Particle density
TP_INIT_RHO(tp)
Tracked_Particle mass
TP_INIT_MASS(tp)
liuhanwen is offline   Reply With Quote
dpm;fluent;udf;injection
UDF for vapor pressure anuarun Fluent UDF and Scheme Programming 13 June 23, 2024 14:12
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
Replicating Scalable Wall Function with a UDF yousefaz FLUENT 0 August 4, 2017 03:30
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
