999999: mpt_accept: error: accept failed
Old   June 27, 2020, 04:49
Default 999999: mpt_accept: error: accept failed
Arun raj.S
arunraj is on a distinguished road
Hello everyone,
I am receiving the following error when I press the initialize button. I have UDM in my code. I have allocated 3 User defined memory locations and 0 User defined node memory locations.
999999: mpt_accept: error: accept failed: No such file or directory
Node 3: Process 21136: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed: No error
Node 4: Process 26964: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed============================================ ==================================: No error
#include "udf.h"
#include "math.h"
#include "sg_udms.h"
#include "sg.h"
#include "stdio.h"
#include "mem.h"
#include "dpm.h"
#include "surf.h"
Domain *d;
Thread *t;
Thread *tve;
Thread *tle;
Thread *t0;
Thread *t0_s;
face_t fve;
face_t fle;
cell_t c;
cell_t c0;
cell_t c0_s;
real temp_cell_ve, press_cell_ve, rho_cell_ve;
real rho_cell_le;
real hfg = 2360000.0;
real R = 8314.0;
real M = 18.015;
real RR;
real s = 0.03;
real po = 101325.0;
real to = 373.0;
real p_op = 13450.0;
real a1, a2, a3;
real mdot;
real pi;
real rho_cell_le;
real rho_cell_ve;
real vel_ve, vel_le;
DEFINE_INIT(my_init_udf,d)
#if !RP_HOST
begin_c_loop(c0,t0)
C_UDMI(c0,t0,0) = 0.0;
C_UDMI(c0,t0,1) = 0.0;
C_UDMI(c0,t0,2) = 0.0;
end_c_loop(c0, t0);
# endif
DEFINE_ADJUST(interfacesimple, domain)
#if !RP_HOST
tve=Lookup_Thread(Get_Domain(1),76); /*velocity inlet ID*/
begin_f_loop(fve, tve)
tle=THREAD_SHADOW(tve);
fle=F_SHADOW(fve,tve);
c0 = F_C0(fve,tve);
t0 = F_C0_THREAD(fve,tve);
c0_s = F_C0(fle,tle);
t0_s = F_C0_THREAD(fle,tle);
temp_cell_ve = C_T(c0,t0);
press_cell_ve = C_P(c0,t0);
rho_cell_ve = C_R(c0,t0);
rho_cell_le = C_R(c0_s,t0_s);
RR = R/M;
pi = po*exp((hfg/RR)*((1/to)-(1/324.7278)));
a1 = (2.0*s)/(2.0-s);
a2 = 1/sqrt(2*M_PI*RR);
a3 = ((p_op+press_cell_ve)/sqrt(temp_cell_ve))-(pi/sqrt(324.7278));
mdot = a1*a2*a3;
C_UDMI(c0,t0,0)=mdot;
C_UDMI(c0,t0,1)=rho_cell_ve;
C_UDMI(c0,t0,2)=rho_cell_le;
vel_ve=C_UDMI(c0,t0,0)/C_UDMI(c0,t0,1);
vel_le=C_UDMI(c0,t0,0)/C_UDMI(c0,t0,2);
end_f_loop(fve, tve)
#endif
DEFINE_PROFILE(vaporside_velocity, tve, i)
#if !RP_HOST
F_PROFILE(fve, tve, i) = -vel_ve;
#endif
DEFINE_PROFILE(liquidside_velocity, tle, i)
#if !RP_HOST
begin_f_loop(fle, tle)
F_PROFILE(fle, tle, i) = vel_le;
end_f_loop(fle, tle)
#endif
arunraj is offline   Reply With Quote
Old   June 27, 2020, 09:27
Default Error in UDF
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Remove all the include files, except udf.h. Those are not required for your UDF.
The problem most likely is because you have declared Domain *d. This is in conflict. Remove this.
Declare all variables within their respective DEFINE_ functions, until you need global ones.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 28, 2020, 05:30
Arun raj.S
Hi vinerm,
Thank you so much for your suggestion.
I have tried as per your instruction but still I am still getting the same error
I followed the following procedure
step1: setup the case
step2: allocate 4 memory locations
step3: initialization.
step4:compile and load UDF.
step5: Function hook ---> Initialization and adjust ---> load
step6: Hook define_profile in velocity and liquid side of the velocity inlet.
I am receiving the error segmentation fault when i press compute.
I tried several other versions too. However, I am receiving the same error
I am not even receiving the message in DEFINE_INIT and DEFINE_ADJUST which I have. Please suggestion modifications in UDF id needed.
#include "udf.h"
Thread *t0;
Thread *tve;
Thread *tle;
cell_t c0;
face_t fve;
face_t fle;
#if !RP_HOST
begin_c_loop(c0,t0)
Message("first udmi is %g\n", C_UDMI(c0,t0,0));
Message("secod udmi is %g\n", C_UDMI(c0,t0,1));
Message("thirs udmi is %g\n", C_UDMI(c0,t0,2));
end_c_loop(c0, t0);
# endif
DEFINE_ADJUST(hp, domain)
#if !RP_HOST
Thread *t0_s;
cell_t c0_s;
real rho_cell_le;
real R = 8314.0;
real M = 18.015;
real RR;
real s = 0.03;
real po = 101325.0;
real to = 373.0;
real a1, a2, a3;
real mdot;
real pi;
tve=Lookup_Thread(Get_Domain(1),20); /*velocity inlet ID*/
c0 = F_C0(fve,tve);
RR = R/M;
mdot = a1*a2*a3;
Message("vapor vel is %g\n", vel_ve);
Message("liquid vel is %g\n", vel_le);
#endif
#if !RP_HOST
#endif
#if !RP_HOST
tle=Lookup_Thread(Get_Domain(1),21);
#endif
Old   June 28, 2020, 06:03
Arun raj.S
Following your previous answer on the below post. I used the below UDF, I am receving the message for vel_ve. However, the problem is in the calculation of vel_le. Could you please suggest some modifications?
Calculating flow variables only once in begin_f_loop()
#include "udf.h"
Thread *tve;
Thread *tle;
Thread *t0;
Thread *t0_s;
cell_t c0;
cell_t c0_s;
face_t fve;
face_t fle;
#if !RP_HOST
begin_c_loop(c0,t0)
end_c_loop(c0, t0);
begin_c_loop(c0_s,t0_s)
C_UDMI(c0_s,t0_s,1) = 0.0;
Message("first udmi is %g\n", C_UDMI(c0_s,t0_s,1));
end_c_loop(c0_s, t0_s);
# endif
DEFINE_ADJUST(heatpipe, domain)
#if !RP_HOST
c0 = F_C0(fve,tve);
real rho_cell_le;
real R = 8314.0;
real M = 18.015;
real RR;
real s = 0.03;
real po = 101325.0;
real to = 373.0;
real a1, a2, a3;
real mdot;
real pi;
RR = R/M;
mdot = a1*a2*a3;
vel_ve=mdot/rho_cell_ve;
vel_le=mdot/rho_cell_le;
C_UDMI(c0,t0,0)=vel_ve;
C_UDMI(c0_s,t0_s,1)=-vel_le;
Message("vel_ve is %g\n", C_UDMI(c0,t0,0));
Message("vel_le is %g\n", C_UDMI(c0_s,t0_s,0));
#endif
#if !RP_HOST
c0 = F_C0(fve,tve);
F_PROFILE(fve, tve, i) = C_UDMI(c0,t0,0);
Message("vel_ve profile is %g\n", C_UDMI(c0,t0,0));
#endif
#if !RP_HOST
F_PROFILE(fle, tle, i) = C_UDMI(c0_s,t0_s,1);
Message("vel_le profile is %g\n", C_UDMI(c0_s,t0_s,1));
#endif
Old   June 29, 2020, 05:42
Default Corrections to the UDF
vinerm's Avatar
Vinerm
You still have variables outside DEFINE_ functions.
The problem is because fve and fle are not available outside f_loop. So, you need to declare those outside f_loop but use only inside the loop, i.e., any command that use either fve or fle as an argument, must be used inside f_loop.
Regards,
Vinerm
Old   June 29, 2020, 10:00
Default UDF uninitialized local variable
Arun raj.S
Dear vinerm,
Thank you for making me understand. I am receiving fresh error. I forgot to mention one thing. le- liquid evaporator and ve - vapor evaporator are not walls. They are velocity inlet. So I believe these commands do not work tle=THREAD_SHADOW(tve); fle=F_SHADOW(fve,tve);
Is there a way to call face and thread of one velocity inlet inside another ? They are shadow velocity inlets not wall. Previously, I remember you saying, it can not be done. I have seen people using something like this ff_shadow=ff_Vapour_liquid [iii];
D:\leonard validation\libudfaabvvvbcccddaa\src\pipe.c(19) : warning C4700: uninitialized local variable 'fve' used
D:\leonard validation\libudfaabvvvbcccddaa\src\pipe.c(125) : warning C4700: uninitialized local variable 'fve' used
#include "udf.h"
Thread *tve;
Thread *tle;
Thread *t0;
Thread *t0_s;
#if !RP_HOST
face_t fve;
face_t fle;
cell_t c0;
cell_t c0_s;
begin_c_loop(c0,t0)
c0 = F_C0(fve,tve);
end_c_loop(c0, t0);
# endif
DEFINE_ADJUST(pipe, domain)
#if !RP_HOST
face_t fve;
face_t fle;
cell_t c0;
cell_t c0_s;
real rho_cell_le;
real R = 8314.0;
real M = 18.015;
real RR;
real s = 0.03;
real po = 101325.0;
real to = 373.0;
real ti = 324.7278;
real a1, a2, a3;
real mdot;
real pi;
c0 = F_C0(fve,tve);
RR = R/M;
pi = po*exp((hfg/RR)*((1/to)-(1/ti)));
a3 = ((p_op+press_cell_ve)/sqrt(temp_cell_ve))-(pi/sqrt(ti));
mdot = a1*a2*a3;
#endif
DEFINE_PROFILE(vaporside_velocity, t, i)
#if !RP_HOST
face_t fve;
face_t fle;
cell_t c0;
c0 = F_C0(fve,tve);
#endif
DEFINE_PROFILE(liquidside_velocity, t, i)
#if !RP_HOST
face_t fve;
face_t fle;
cell_t c0_s;
#endif
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
