Renaming files in loop using scheme
Old   June 19, 2020, 14:01
Default Renaming files in loop using scheme
Manish Vankudre
manish1308 is on a distinguished road
Hi I am trying to use scheme to rename my files.
I found the command (rename-file "first_file.csv" "second_file.csv"). This helps me to rename a single file.
I want to use it in a loop to rename multiple files. How can I do that?
I tried using something like this-
(do ((x 2 (+ x 1))) ((> x3))
(rename-file ("Wallprof_Csv_~a.c" "output_~a.c" x x )))
But this does not work.
Can you guys help me out with this.
Thank you.
manish1308 is offline   Reply With Quote
Old   June 19, 2020, 15:23
Default Renaming Files
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Why do you want to use Fluent to rename files? Use bash (or batch or powershell, if using Windows) to do that. Though it can be done yet Fluent is not meant for renaming files.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 19, 2020, 16:24
Manish Vankudre
I am running a do loop which has scheme commands to run the entire simulation. So I need to use the rename command in this do loop. Can you please let me know how can I use rename file in a do command. If I can get that done I am able to solve the whole issue.
Can you please let me know how it is done in Fluent. It would be a great help.
Thanks,
Manish
Old   June 19, 2020, 16:32
Default Format
vinerm's Avatar
Vinerm
The command does work the way you are using. However, if you want to replace ~a with some variable, you need to use format command.
Regards,
Vinerm
Old   June 19, 2020, 16:45
Manish Vankudre
Hi.
I am trying to use this command. But it is giving me an error.
I also tried putting the whole thing in a bracket.
(do ((x 2 (+ x 1))) ((> x 3))
(rename-file (format #f "test_~a.csv" "output_~a.csv" x x )))
Old   June 20, 2020, 12:04
Default format
vinerm's Avatar
Vinerm
rename-file expects two arguments. So, you need to use format twice, working on each file separately.
Regards,
Vinerm
Old   June 21, 2020, 22:33
Default format
Manish Vankudre
Sorry I didnt get you. So does that mean I cannot use rename in a loop?
Old   June 21, 2020, 22:47
Default format
Manish Vankudre
Hello Sir,
I got what you were trying to imply. I was able use rename in the loop.
Thank you so much from your help.
Thank you,
Manish
scheme language., scheme programming
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 13:29
can you tell me best gradient, pressure & momentum order selection in fluent sanjiiv FLUENT 6 February 14, 2020 07:07
Writing Case and Data Files Using Journal/Scheme Files svp Fluent UDF and Scheme Programming 0 April 5, 2011 12:04
Scheme documentation and question Mickaël Perrin FLUENT 0 July 4, 2002 06:21
[making animations] fclose fails to close files? Mika FLUENT 0 March 30, 2001 09:19
