Changing input variable using UDF
Old   June 11, 2020, 11:26
Default Changing input variable using UDF
Manish Vankudre
manish1308 is on a distinguished road
Hello everyone,
I have created a parameter named "parameter-1" using the input-parameter TUI command. I have created the parameter to be used in udf-side and it says the (id to be used in udf is- "real-1").I am able to access the parameter in the UDF by using the command RP_Get_Input_Parameter("real-1").
Now I want to change the value of this variables using the UDF . Is it possible to do so?
Any help is appreciated.
Thank you
manish1308 is offline   Reply With Quote
Old   June 12, 2020, 01:48
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
RP_Set_Real("real-1",value);
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
fluent, fluent - udf
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 13:35
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 19:58
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
Fluent UDF: Thru external input BS FLUENT 0 March 26, 2008 19:53
UDF compilation problem -- "undeclared variable" Henrik Ström FLUENT 1 September 21, 2005 06:25
