UDF for calculating angular velocity in a rotating tank |
June 18, 2020, 13:26 |
#21 |
The image you have shared is not very clear about which one is axis and which one is radial direction.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 18, 2020, 14:21 |
#22 |
vav noon
Rep Power: 6 |
Sorry, the following is more clear. The tank rotates around the y-axis and the plane including the polar coordinates coincides with the x-z plane.
June 19, 2020, 06:40 |
Results
#23 |
The results are as they should be. There is no vortex, it is just the effect of the axis of rotation. If you want vortex, then do not rotate the cell zone. Only set the outermost wall as a moving wall.
June 20, 2020, 04:29 |
#24 |
vav noon
Rep Power: 6 |
Dear Vinerm,
Could you please give me more explanation? I think in this case the mesh rotates at the same speed as the tank and it doesn't have any deformation. Using mesh motion, we don't have mesh deformation. The cells experience a rigid motion. Furthermore, using the material definition as fluid (having viscosity property) and wall existence, it is expected that the fluid motion be not rigid. As we know, the relative motion between fluid and mesh is considered in Navier-Stokes eq. in the sliding mesh. I think if I just rotate walls, the mesh will be deformed. What do you think in this regard? Thank you so much for your time |
June 20, 2020, 15:42 |
Mesh Motion and Fluid Motion
#25 |
By providing rotation to whole mesh zone, you are stating that whole fluid should rotate as a rigid body. Whether it should be mesh motion or moving wall, depends upon the objective of the simulation as well as the physics. In case there is any impeller that is making the fluid rotate, then you should use that impeller and give either frame motion or mesh motion to the region containing the impeller. However, if it is a kind of a drum or barrel containing fluid and is rotating, then using mesh motion is incorrect. You need to give motion to wall.
Moving wall is not deforming mesh approach. The mesh is always fixed. Navier-Stokes equation has no concept of mesh of any type. Eulerian frame always has fluid motion relative to mesh. But whether the mesh should move or not depends on the physical phenomenon.
June 28, 2020, 02:35 |
#26 |
vav noon
Rep Power: 6 |
Dear Vinerm,
Many thanks for your reply. If the cross-section is non-circular, am I able to use just moving wall? Could you please guide me? Thanks |
June 30, 2020, 10:57 |
#27 |
vav noon
Rep Power: 6 |
Does it need to use DEFINE_GRID_MOTION macro?
Thank you |
UDF for inlet velocity alongwith UDF for properties | akshayy224 | FLUENT | 0 | February 1, 2018 10:17 |
[Transient Simulation] Angular Velocity dependent on different parameters than time | ThalesMachado | CFX | 1 | July 28, 2017 07:36 |
UDF for time dependent angular velocity calculation | shashankmechguy | Fluent UDF and Scheme Programming | 2 | October 24, 2016 05:43 |
UDF for defining a body force in Singel ROtating Reference Frame | teymourj | Fluent UDF and Scheme Programming | 9 | August 18, 2016 16:33 |
UDF velocity and temperature | Raj | FLUENT | 3 | February 1, 2009 19:29 |
