Species mass transfer UDF
Like Tree4Likes
Old   May 31, 2020, 10:02
Anshuman Sinha
Anshs is on a distinguished road
I meant to say, the conditional statement is not working. The mass transfer is working on the full fluid phase. Rest of it is fine.
Thanks.
Anshs is offline   Reply With Quote
Old   May 31, 2020, 16:43
Default Condition statement
  #22
Anshuman Sinha
Originally Posted by vinerm View Post
What do you mean by not working? Is it not compiling, or giving run-time error, or giving wrong values?
Fluent does not accept // for comments. So, either use /* */ or remove comments altogether.
The condition statement for interfacial mass transfer is not working.
Thanks
Old   June 2, 2020, 06:44
Default Volume Fraction Value
  #23
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
That won't have any effect if both the phases are rather well-mixed, otherwise, it should work. Try plotting volume fraction of phases.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 2, 2020, 08:18
Default Volume fraction contours
  #24
Anshuman Sinha
I did plot the volume fraction.
The image below represents the mass transfer which I have used
Initial Volume fraction: Water
Oil
Phase interaction: mass transfer: after 100 timesteps.
Old   June 2, 2020, 08:53
Default Phases
  #25
vinerm's Avatar
Vinerm
How many phases do you have? Since the right-most region neither has water nor oil. So, is there a third phase?
Anshs likes this.
Regards,
Vinerm
Old   June 2, 2020, 09:36
Default Phases
  #26
Anshuman Sinha
Yes there re 3 phases.
Old   June 2, 2020, 09:42
Default Mass Transfer
  #27
vinerm's Avatar
Vinerm
Do you want mass transfer from gas to water or gas to oil? You have to ensure that you have selected correct phases under From and To in Mass Transfer Panel.
Regards,
Vinerm
Old   June 2, 2020, 10:17
Default water to oil.
  #28
Anshuman Sinha
None, I want mass transfer (species) from water to oil. I have posted the 'phase interaction tab' in the reply as well. you may have a look.
Thanks
Old   June 2, 2020, 10:27
Default Water to Oil
  #29
vinerm's Avatar
Vinerm
Your post does not contain Mass Transfer Tab. Anyway, then make changes to your code and use oil in place of gas. Though that is just a variable name yet it helps to remove ambiguity. Furthermore, to debug the code, try to make the condition even stricter. Use product of C_VOF(c, t, water) & C_VOF(c, t, oil) to define m_lg. This will have a non-zero value only at the interface of water and oil.
Anshs likes this.
Regards,
Vinerm
Old   June 4, 2020, 14:58
Default problem with 3rd phase.
  #30
Anshuman Sinha
The mass transfer is working fine between water and oil phase, but it is also operating in some region between water and air (3rd phase).
Phases: Screenshot 2020-06-04 at 11.19.16 PM.jpg
Mass transfer rate: mt.jpg
UDF:
#include "udf.h"
DEFINE_MASS_TRANSFER(interface_transfer, cell, thread, from_index, from_species_index, to_index, to_species_index)
real m_lg;
Thread *water = THREAD_SUB_THREAD(thread, from_index);
Thread *oil = THREAD_SUB_THREAD(thread, to_index);
m_lg = 0.0;
if ( C_VOF(cell,water)*C_VOF(cell,oil) != 0 )
/*m_lg = 0.1*C_VOF(cell,gas)*C_R(cell,gas)*
fabs(t_sat -C_T(cell,gas))/t_sat;
m_lg = 0.1* C_VOF(cell,gas) * C_R(cell,gas) * C_YI(cell , gas , 0) ; */
m_lg = 100;
/* here C_YI(c, gas, 0 ), denotes species mass fraction of 1st species in the mixture denoted by phase 'gas'.*/
else m_lg = 0.0;
return (m_lg);
Old   June 4, 2020, 15:09
Default Three Phases
  #31
vinerm's Avatar
Vinerm
That's because there are three phases. I suggested product of volume fractions assuming there are two phases. But with three phases, even with 0.1 volume fractions of water and oil, the condition matches, despite there being 80% air. So, you have to use a condition wherein the air content is extremely low. Ideally, this would mean that the product of volume fractions of oil and water should be 0.25. But that's ideal case, not practical. So, a better approach would be to ensure that the sum of water and oil volume fraction is close to 1, say, above 0.95, as well as their product is close to 0.25, say, above 0.21. These two conditions should get you closer to expected result.
Regards,
Vinerm
Old   June 4, 2020, 15:55
Anshuman Sinha
Yes, but the triangular region has th water phase there! so how is the previous surface condition getting satisfied there?
Thanks
Old   June 4, 2020, 17:03
Default Condition
  #33
vinerm's Avatar
Vinerm
That's because the condition is for the product not to be 0, so, even if it is 0.9999 * 0.00001, it's not 0.
Regards,
Vinerm
Old   June 4, 2020, 17:08
Anshuman Sinha
Okay so basically that's because of the limit to which the solver is storing data!
Thanks!
Old   June 4, 2020, 17:33
Default Precision
  #35
vinerm's Avatar
Vinerm
Solver stores data up to about 32 or even more decimal places.
Regards,
Vinerm
Old   July 28, 2020, 09:30
Default UDF help for the same thread
  #36
Anshuman Sinha
I have written the code where 'DEFINE_ADJUST(store_gradient, domain)' is calculating the area density of the cell, so that it can be used in the 'mass transfer' expression.
1. I think I can't write the function like this inside another function.
2. Shall I separate the area function ( DEFINE_ADJUST(store_gradient, domain) ) outside the mass transfer function?
#include "udf.h"
#include "math.h"
real m_lg;
real c_tg;
real k_g;
m_lg = 0.0;
c_tg = 0.0;
k_g = 0.0;
if ( ( C_VOF(cell,water)*C_VOF(cell,oil) > 0.21 ) && (C_VOF(cell,water) + C_VOF(cell,oil) >0.95) )
k_g = 0.4 * sqrt(C_DIFF_L(cell,water,0,1)) * pow((C_D(cell,water)/ C_MU_T(cell,water)), 0.25)
c_tg = C_VOF(cell,water) * C_R(cell,water) * C_YI(cell , water , 0) ;
m_lg = k_g * (NV_MAG(C_VOF_G(c,ppt))) * ( 4e-5 - c_tg ) ;
else m_lg = 0.0;
return (m_lg);
Old   July 28, 2020, 09:54
Default Modifying this in the above thread.
  #37
Anshuman Sinha
Originally Posted by Anshs View Post
Yeah, I got your point. In the mass transfer tab of phase interaction, we will need to put on these specific details.
One more thing, if I want to further modify the transfer rate as given in the picture below.
Attachment 78037
#include "udf.h"
DEFINE_MASS_TRANSFER(liq_gas_source, cell, thread, from_index,
   real m_lg;
   real T_SAT = 373.15;
   Thread *gas = THREAD_SUB_THREAD(thread, from_index);      // gas phase
   Thread *liq = THREAD_SUB_THREAD(thread, to_index);          // liquid phase
   m_lg = 0.;           // initialisation
   if ((m_lg == 0. ) && (C_T(cell, gas) <= T_SAT))
         fabs(T_SAT-C_T(cell,gas))/T_SAT;
         D = DEFINE_DIFFUSIVITY*(*name,*c,*t,*I)
         X_co2_eq= 0.1;
         X_co2 = C_VOF(cell,gas) * C_R(cell,gas) * C_YI(c , gas , 0)*
         k = 0.4*sqrt(D)*(C_D(c,t)/ C_MU_T(c,t)).^0.25
         //a = interfacial area/volume
 , I have the separate UDF for this
         m_lg = k*a* ( X_co2_eq - X_co2);
         //here C_YI(c, gas, 0 ), denotes species mass fraction of 1st species in
   return (m_lg);
Is this correct? Thanks
Old   August 18, 2022, 21:19
vikash
vikash0603 is on a distinguished road
I am dealing with a single phase(having two species of water and ethanol). water and ethanol are entering from two different inlets. How can I write UDFs for a single phase and multiple species?
vikash0603 is offline   Reply With Quote
Old   August 18, 2022, 21:30
vikash
fluent, mass transfer, species tranport, udf
Accessing phase interaction mass transfer rate in UDF ahmadimo Fluent UDF and Scheme Programming 1 October 7, 2021 00:08
species transport, mass transfer rate mattK FLUENT 4 September 16, 2021 15:22
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
UDF Source Terms: Both Species and Mass? Baum Fluent UDF and Scheme Programming 5 April 17, 2020 10:11
Species Mass Transfer Abu-Khawlah FLUENT 0 December 9, 2005 11:35
