Why so many nodes in output file?
Old   May 22, 2020, 03:57
Question Why so many nodes in output file?
Ma qiyu
Sunmax is on a distinguished road
I found that when using udf to output the mesh node coordinates, the number of the nodes were incredibly large.
I don't know what makes this wrong, so I put the udf below and hope someone can give a reasonable explanation.
#include"udf.h"
#define PLATE_ID 5
DEFINE_EXECUTE_AT_END(Coordinate)
    Domain *d = Get_Domain(1);
    Thread *tf = Lookup_Thread(d, PLATE_ID);
    face_t f;
    FILE *NX, *NY, *Num;
    int n, count = 0;
    Node *v;
    real x, y;
    begin_f_loop(f, tf)
    	f_node_loop(f, tf, n)
    		v = F_NODE(f, tf, n);
    		x = NODE_X(v);
    		y = NODE_Y(v);
		NX = fopen("node_x.txt", "at+");
    		fprintf(NX, "%f,", x);
    		fclose(NX);
                NY = fopen("node_y.txt", "at+");
                fprintf(NY, "%f,", y);
                fclose(NY);
                ++count;
    end_f_loop(f, tf);
    Num = fopen("Num_nodes.txt", "at+");
    fprintf(Num, "Num of nodes=%d", count);
    fclose(Num);
In my case, the real number of nodes on the plate is 2036, but that is 4072 in the Num_nodes.txt, exactly two times of the real one.
Sunmax is offline   Reply With Quote
Old   May 22, 2020, 06:36
Default Nodes
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The nodes are not unique for each face but are shared. The number of faces sharing a node depends on the type of mesh. Therefore, many nodes are visited multiple times and the count goes wrong.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 22, 2020, 07:31
Thumbs up
Ma qiyu
Thank you very much for the explanation of the mechanism. I need to use the coordinates to control the dynamic mesh deformation in a special way, although I found that the udf(another one) could work well in serial processing which could not be used in parallel processing. So I guess it is the output-coordinates that causes the problem.
Old   May 24, 2020, 07:48
Default Output Coordinates
vinerm's Avatar
Vinerm
What do you mean by output coordinates? There is no problem here except that the nodes are being visited multiple times.
Regards,
Vinerm
Old   May 24, 2020, 09:02
Ma qiyu
I need the coordinates of two adjacent nodes to calculate the distance between them, the udf macro NODE_X(v) could not be used as NODE_X(v+1) so I have to output the coordinates. But there is another problem that the order of the coordinates is messy.
Old   May 25, 2020, 11:22
Default Nodes
vinerm's Avatar
Vinerm
v and v+1 may or may not be adjacent. Try using v->next, though I am not clear about the structure but node structure most likely is based on linked list and you should be able to access next node using next. But even with that, it is not guaranteed that next node is also adjacent node. So, the fool proof method is to compare the coordinates.
Regards,
Vinerm
Old   May 28, 2020, 05:48
Ma qiyu
I found another interesting issue if I add the if(n==0) before the node_loop, the nodes will be visited only one time. But why?
begin_f_loop(f, tf)
	if ( n==0 )
	   F_AREA(A, f, tf);
	   v=F_NODE(f, tf, n);
	   ve = F_V(f, tf);
	   NV_VS(pl,=,A,*,F_P(f,tf));
	   NV_VS(pl,=,pl,*,ve);
	   NV_V(pl_tot, +=,pl);
end_f_loop(f,tf);
Old   May 28, 2020, 05:55
Default Logic
vinerm's Avatar
Vinerm
That's because the loop goes over values of n. With If condition, you are constraining the loop to one instance, only when n = 0. So, the loop is executed only once.
Regards,
Vinerm
Old   May 28, 2020, 06:05
Ma qiyu
And one more question, are there any side effects if I use the if-condition to constrain the node_loop?
Old   May 28, 2020, 06:12
Default Effects
vinerm's Avatar
Vinerm
There are no side-effects, just the effects. The parts of the code within the confines of the If condition will be executed only if the condition is true. If you are thinking of using If to control the number of loops, then the logic wrong. The loop goes over all the nodes only once, there is no problem with that. The issue you are facing is because nodes are not unique to the cells or the faces. Each node is shared.
Regards,
Vinerm
node, udf
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
