October 5, 2022, 11:15 |
#21 |
M. Asif
Dear Vinerm can you please explain clearly how to express partial pressure in the rate equation using incompressible ideal gas law. I have set operating pressure as 1 atm and initial gauge pressure as zero, and my pressure outlet gauge pressure is also zero.
January 3, 2023, 10:21 |
Argument type confusing question
#22 |
Daniel Z
Hi zaixing!
previous I have learned the MSRR reactions for H2 production, fortunately, I have discovered this thread you have written before. here I have a question, I note that the code you posted concluded has more than one reaction defined. however, the Macro DEFINE_VR_RATE returns the reaction rate with rr and rr_t, but in your code, the reaction-1 only returns a real value defined as "r_MSR". can the r_MSR be worked as rr and rr_t? this thread has posted long ago, I hope you can see this message. Best regards! |
udf for one dimensional linear motion based on force | maccheese | Fluent UDF and Scheme Programming | 2 | September 1, 2019 03:18 |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 13:43 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 01:53 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
