Friction pressure by Johnson and Jackson model |
May 3, 2020, 06:06 |
wuming
Rep Power: 8 |
Dear all,
I'm simulating a multiphase flow using Fluent with air and a granular phase (TFM approach). I used the Johnson and Jackson model to calculate the friction pressure, and I also wrote a UDF about this friction pressure model. Choose the same friction viscosity model. However, the frictional viscosity calculated by these two models is different, the friction viscosity calculated using UDF is greater and the ratio is equal to 1.25. Johnson and Jackson model: the part of the UDF I write: DEFINE_PROPERTY(cell_fri_pressure,cell,mix_thread) { void_s = C_VOF(cell, mix_thread); a = void_s - alpha_min; b = alpha_max - void_s; aa = pow(a,2.0); bb = pow(b,5.0); if (void_s < alpha_min) { fri_pressure = 0.0; } else { fri_pressure = 0.1*void_s*aa/bb; } return fri_pressure; } Unfortunately, I cannot understand this result. Can you explain this reason? Thank you in advance! |
May 3, 2020, 16:42 |
Frictional Pressure
What values are you using for minimum and maximum packing limits?
And prefer not to call the argument mix_thread since it is phase thread. Though it is just a variable name, it can lead to wrong understanding.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 3, 2020, 21:59 |
wuming
Rep Power: 8 |
minimum and maximum packing limits are equal to Friction Packing Limit and Packing Limit which defining in Granular Secondary Phase,respectively. The minimum packing limit is 0.5,maxium is 0.61 in two cases.
May 5, 2020, 06:01 |
Frictional Pressure
Select Johnson model for frictional pressure and then fetch the values calculated by Fluent, preferably save in UDM. Compare it with the values calculated by Fluent. For fetching values calculated by Fluent, you can use generic_property function with PROP_mpg_friction_p as property ID.
May 6, 2020, 06:17 |
#5 | |
wuming
Rep Power: 8 |
I use this property ID, but the result is all 0. I think my UDF is written correctly, I can get accurate results by using PROP_rho as property ID.So where did I wrong?? Thank you in advance! sp = THREAD_MATERIAL(thread_s); prop = (MATERIAL_PROPERTY(sp)); pc = generic_property(cell,thread_s,prop,PROP_mpg_frict ion_p,293.); |
May 6, 2020, 06:21 |
Loop and Thread
You have to ensure that the loop used and the Thread passed are correct. Check some other property, such as, diameter of secondary phase.
May 7, 2020, 00:16 |
wuming
Rep Power: 8 |
May 7, 2020, 06:12 |
Density and Viscosity
These properties are generic. Try to fetch the properties defined under Secondary Phase panel and not under Materials Panel, such as, frictional viscosity.
May 7, 2020, 08:54 |
#9 |
wuming
Rep Power: 8 |
May 7, 2020, 09:05 |
Loop
#10 |
That can be used only if you have species transport enabled. Otherwise, it has to be mp_thread_loop_c
May 8, 2020, 10:22 |
#11 | |
wuming
Rep Power: 8 |
Thank you in advance!! DEFINE_PROPERTY(cell_fri_viscosity,cell,mix_thread ) { Thread *cell_thread, *thread_s, *t, **pt; real pc; Material *sp; Property *prop; Domain *domain; domain = Get_Domain(1); mp_thread_loop_c(mix_thread,domain,pt) { sp = THREAD_MATERIAL(pt[1]); prop = (MATERIAL_PROPERTY(sp)); pc = generic_property(cell,pt[1],prop,PROP_mpg_friction_p,293.); C_UDMI(cell, mix_thread, 3) = pc; } .... return fri_viscosity; } |
May 8, 2020, 13:09 |
generic_property
#12 |
Actually, generic_property is not used for phase properties. It is useful only for species properties. There is a function that directly fetches value for frictional pressure for a given set of arguments. So, if you execute the following command within any UDF, it returns frictional pressure value
Get_Frictional_Pressure(10, 0.62, 0.775, 0.63, 0.61)); Here, first argument is ID for the frictional model, 10 identifies Johnson model. You can use 11 for Syamlal and 12 for ktgf. Second argument is the volume fraction for which you want to fetch value of Frictional Pressure. Last two arguments are packing limit and friction packing limit. However, I am not very sure of third argument. This is also volume fraction but whether it is maximum value of vf used for heat and mass transfer iac calculation or some other value, I am not sure. It also affects the frictional pressure but not a lot.
May 11, 2020, 09:40 |
#13 | |
wuming
Rep Power: 8 |
May 11, 2020, 11:54 |
Good
#14 |
It's good then.
generic_property loop works only with species and for generic properties that are given in Materials panel. For phase properties, there is as such no loop or function, at least not one that a user can make use of.
udf |
Ansys Fluent 12.1 Johnson Jackson BC | jipaz | FLUENT | 1 | May 3, 2019 10:55 |
Multiphase flow-Euler(Granular) model | us | FLUENT | 0 | June 10, 2005 12:12 |
