MHD module variables
Old   May 2, 2020, 00:27
Default MHD module variables
Rodrigo Villarreal
rodrigovime is on a distinguished road
Hello, I'm trying to simulate a welding arc to explore the capabilities of the MHD module but for some reason, I can't graph the vectors of current density (J) and electric field (E) after the calculations in the Results tab. Do I have to export them to other software?. If so please tell me how.
Regards,
RVM
rodrigovime is offline   Reply With Quote
Old   May 2, 2020, 17:06
Default Vector Fields
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Whichever field is solved in Fluent can be post-processed within Fluent and an external tool is not required until and unless there is some special requirement, such as, direct comparison of two or more cases. If the fields do not show up under Contours or Vectors or Plots, then either the fields were not solved for or the case is corrupt.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 3, 2020, 02:14
Rodrigo Villarreal
Thank you for your answer. I'll check if the case files are corrupted.
arc simulation, fluent, mhd
External Magnetic Field Data Format for FLUENT MHD Module eduardvinter FLUENT 0 January 24, 2019 02:54
Why is my rhopimplefoam crashing? marxlolop OpenFOAM Running, Solving & CFD 1 January 6, 2019 17:39
How to configure settings in the MHD module? sd_abs FLUENT 1 June 19, 2015 18:27
Inquiring the using method of MHD module transient_13 Fluent UDF and Scheme Programming 1 January 10, 2015 07:25
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 22:51
