fscanf to read scientific notation
Old   April 22, 2020, 13:30
Default fscanf to read scientific notation
j
buckngnr11 is on a distinguished road
My udf writes (fprintf) some small numbers to .txt files in scientific notation. When I try to use fscanf later to read the file, I get nonsense values. As shown, the numbers in the file are on order of e-8 to e-15 or so. What is read into and shown in the console is nonsense of order e-314. I tried different char values, %f, %g, %e. These all work when writing the data to the file, but don't work when reading it. I have another variable that is an integer list and that one writes and reads in just fine. Any ideas how to fix this?
Thanks!
buckngnr11 is offline   Reply With Quote
Old   April 22, 2020, 14:09
Default Specifiers
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If you are running simulation in double precision, you need to use %le and not %e. You may also be able to read using %lf. Usually, %e or %le are not meant for reading, only for writing. But l is certainly required in your case if it is double precision.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
fscanf
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Parallel Error in ANSYS FLUENT 12 zeusxx FLUENT 25 July 17, 2015 05:40
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 10:46
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
