UDF for wall shear stress
Old   March 27, 2020, 00:02
Smile UDF for wall shear stress
HL
Anticip is on a distinguished road
hello,
I want to define a wall boundary with different wall shear stress, but the other part in this wall I want to keep it to no-slip. So how can I DEFINE a no-slip boundary?
THANKS!
Anticip is offline   Reply With Quote
Old   March 27, 2020, 04:41
Default Wall Shear Stress and No-Slip
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The simplest option would be to divide the wall into multiple sections. Apply shear stress on the sections you want stress to be applied and no-slip on the other sections. With UDF, it might be little difficult. UDF needs to be hooked somewhere. If you hook it for stress on the wall, it would not be easy to apply no-slip, since you will be able to apply the gradient of velocity while no-slip implies that velocity should be 0.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 27, 2020, 05:05
HL
Thanks for your suggestion.
no-slip boundary, udf, wall shear stress
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" Jeremie84 ANSYS Meshing & Geometry 70 October 25, 2017 17:03
Fluent UDF Wall Shear Stress Segmentation Fault a1ananth Fluent UDF and Scheme Programming 3 February 24, 2015 04:23
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 07:41
UDF for wall shear stress Bastian FLUENT 0 July 21, 2004 05:52
Help on UDF: access to wall shear stress Zhihua Li FLUENT 2 May 26, 2004 12:55
