Error of UDF paralization (libudf.dll : fatal error LNK1120: 4 ) |
March 11, 2020, 10:43 |
#21 |
Steve
Rep Power: 6 |
Dear Vinerm,
Thank you. I don't find Developer or x64 or x86 command prompt. Neither do I find it when I search the install folder of VS2010. |
March 11, 2020, 10:49 |
Version
#22 |
This might also be version dependent. Search by command or vs and then look within the results if it shows anything that is command prompt from VS.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
March 11, 2020, 10:58 |
Try the code attached
#23 |
Try compiling the usual way with the file that I have attached. Its the same file with minor modifications.
March 11, 2020, 11:02 |
#24 |
Steve
Rep Power: 6 |
Dear Vinerm,
I got the developer command prompt and opened it in 64bit. But I couldn't cd the path to the folder containing the fluent.exe. Thank you very much. |
March 11, 2020, 11:07 |
Commands
#25 |
In Windows, you cannot cd to a path directly if it is in a different drive. First, you need to change drive. Best would be to go the directory where you have your UDF source and case file. If it is F:, then simply use cd. If not, then use the name of the drive. E.g., if you want to change to drive c, then give command c:. Once in the directory where you have the file, use full path to start Fluent, i.e., C:\Program Files\Ansys Inc\v180\fluent\ntbin\win64\fluent.exe
March 11, 2020, 11:36 |
#26 |
Steve
Rep Power: 6 |
Dear Vinerm,
I have tried both methods you mentioned. Unfortunately, both failed eventually. Still puzzled. Thank you. |
March 11, 2020, 11:39 |
Try a simple one
#27 |
Try with a very simple program
#include "udf.h" DEFINE_EXECUTE_ON_LOADING(test, libtest) { #if !RP_HOST Message0("This one works\n Hopefully\n"); #endif }
March 11, 2020, 12:05 |
#28 |
Steve
Rep Power: 6 |
Dear Vinerm,
The simple code is successful. Then the former UDF success too. It is really amazing!!! Thank you very very very much from my deep heart. Salute!!! |
March 11, 2020, 13:06 |
Good
#29 |
Nice to know that it finally worked.
March 12, 2020, 01:10 |
#30 |
Steve
Rep Power: 6 |
Dear Vinerm,
Thank you. It is my first time that I posted a thread here and received your nice respond. It is no exaggeration to say this is an awesome experience. Now I am attempting to do simulation in HPC environment. Thank you again. |
March 12, 2020, 07:51 |
Welcome
#31 |
Welcome to the Party
error, libudf, paralization, udf |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
UDF problems...FATAL ERROR! | Paolo Lampitella | FLUENT | 1 | September 8, 2005 11:07 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
