UDF code for porous media model
Old   March 6, 2020, 06:52
Default UDF code for porous media model
Chahat Jain
Rishabh0010 is on a distinguished road
How to write UDF code for the porous media model equations in 2-d simulation of the porous wick
Rishabh0010 is offline   Reply With Quote
Old   March 6, 2020, 08:14
Default Porous Media Model
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Could you elaborate little more on porous media model? Do you mean Carman-Kozeny or Ergun or some other? Do note that Fluent already incorporates a porous media model. You can use it for 2D as well as 3D.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 11, 2020, 07:34
Chahat Jain
Thank you, sir, for responding. In our model, we have considered the evaporation and condensation process simultaneously. We are simulating the porous wick in the loop heat pipe.
Old   March 11, 2020, 08:11
Default EC model and porous media
vinerm's Avatar
Vinerm
EC model is separate from porous media. You can use EC model and porous zone in a single case. What I do not understand is your requirement for a UDF. Since both are available within Fluent as inbuilt models, you might be able to directly use those.
However, as far as wick modeling is concerned, it is not easy. There is a considerable amount of physics with myriad of phenomena to be considered.
Regards,
Vinerm
Old   August 4, 2020, 03:08
Debojit Sharma
scorpian is on a distinguished road
How to get the gradient of species mole fraction in fluent?
scorpian is offline   Reply With Quote
UDF for improved coal devolatilization model in fluent(devolatilization ) magic0801 Fluent UDF and Scheme Programming 3 May 23, 2023 06:18
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 21:21
porous media turbulent model P-dL, I get the different results? is the model wrong? hitchenxue FLUENT 0 July 13, 2014 06:57
UDF code yahya_azizi Fluent UDF and Scheme Programming 1 July 16, 2012 11:50
Use of an hydrodynamic model integrated in the vertical by the PHOENICS code Hafsia Zouhaier Main CFD Forum 2 March 15, 1999 09:23
