UDF for Transient Modelling (temperature)
Old   March 1, 2020, 02:17
Default UDF for Transient Modelling (temperature)
Julianne Denise
jdbm is on a distinguished road
I'm completely new when it comes to coding and I'm still quite confused with how it works. I'm doing a project where I'm trying to model temperature through transient modelling. I have clusters of buildings (outdoor) and I'd like to show how temperature changes over time in locations such as the corners and sharp edges. I would just like to ask for help on how should I go about this in creating a code that does a transient model of temperature. Any help or advice would be appreciated.
jdbm is offline   Reply With Quote
Old   March 1, 2020, 05:57
Default Transient Modeling
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Transient modeling does not require any UDF or code. The feature is in-built.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 1, 2020, 10:25
Julianne Denise
Yes, I understand that but wouldn't coding be required in getting more 'accurate' results? Please do correct me if I am wrong.
Old   March 1, 2020, 10:33
Default Code and Accuracy
vinerm's Avatar
Vinerm
Accuracy has got nothing to do with the coding. Coding is required to implement user defined features that are not built in. Accuracy does not require code rather validation.
Regards,
Vinerm
UDF to get the average temperature of a face and use it to define a property gdb Fluent UDF and Scheme Programming 19 November 3, 2022 04:11
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) dillon Fluent UDF and Scheme Programming 3 March 25, 2018 12:06
UDF problem- time dependent temperature at inlet kaeran FLUENT 1 June 16, 2015 22:48
How to do UDF for temperature profile on a semi-disc? Reivax Fluent UDF and Scheme Programming 5 April 7, 2015 23:54
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 19:29
