Problem with moving mesh and species transfer |
February 18, 2020, 08:11 |
Rep Power: 7 |
I have a problem with using dynamic mesh and species transport at the same time. When I run a simulation without species transport, my mesh moves, but when I enable the species transport model fluent crashes. Can anybody help me with this problem? For the dynamic mesh motion I used the example from the udf-guide. Thank you :-) |
February 18, 2020, 08:59 |
Other way around?
Does the simulation work the other way around, i.e., if you enable species transport but not the dynamic mesh?
It is possible that the species transport setup has a problem. Furthermore, if you are using a UDF from an example, ensure that it is compatible with the species transport model. Usually, a dynamic mesh UDF has got nothing to do with a species or material properties but in case the UDF accesses any such parameter, then it would require little modifications.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 18, 2020, 09:08 |
Rep Power: 7 |
Yes, I tried to run only the species transport, and it also works fine.
I just tried a very simple udf. The mesh is moving only in x-direction with NODE_X(v) += 1.0e-8; So it is independent from species transport, and I thought I can use both at the same time, because there is no coupling, or something like that... But maybe I have to enable something in fluent, or I have to include some *.h files, but I don't know... |
February 18, 2020, 09:52 |
Udf
Is that the complete UDF source? You need to include udf.h. Furthermore, NODE_X does not provide motion. It returns position of the node.
February 18, 2020, 10:04 |
Rep Power: 7 |
No, this is not the complete udf.
It is what I wrote in the f_node_loop. The udf works fine, if I don't use the species transport. For other fluent cases I also use udfs for moving mesh, and I don't have any problems, if I don't use species transport... And as I said, I also tried the udf from the udf-user-guide for the grid motion. Without species it works fine... |
February 18, 2020, 12:48 |
Dynamic mesh and species transport
There's no compatibility issues between dynamic mesh and species transport. However, sometimes the order matters. Does the successfully running dynamic mesh case has species transport enabled but equations disabled for solving or does it not have species transport enabled at all and when the species transport is enabled, Fluent crashes?
February 18, 2020, 15:42 |
Debugging
I'd recommend using dynamic mesh without the UDF for debugging the case. Enable species transport and dynamic mesh but use a profile instead of a UDF for the motion. Profile format for dynamic mesh is simple; similar to a transient file except the names for the variables are hard coded. So, for velocity along x-coordinate, use v_x. If this works, then, most likely, the issue is with the UDF.
February 19, 2020, 00:42 |
#8 | |
Alexander
Rep Power: 34 |
best regards ****************************** press LIKE if this message was helpful |
February 19, 2020, 02:06 |
#9 | |
Rep Power: 7 |
Thank you, I will try this |
February 19, 2020, 02:09 |
#10 | |
Rep Power: 7 |
I think, the problem is in the species transport setting, but I don't know... I can run a case with only moving mesh, and a case with only species transport, but I can't run a case with both together... |
February 19, 2020, 04:25 |
Code
#11 |
If there is nothing proprietary in the code, I'd recommend you share it in full and we can have a look. Having a problem in Species transport is a possibility but if it runs without dynamic or moving mesh, it should run with it as well until unless there is a conflict. And that seems to be the reason here.
February 25, 2020, 09:20 |
#12 |
Rep Power: 7 |
Now I solved the problem. I reset the fluent case and startet over. Now I can run the simulation with species transport and moving mesh.
Thank you for your help! |
February 25, 2020, 09:25 |
Good
#13 |
Nice to know that it works now. Good experience, I suppose.
Dynamic mesh & Negative volume in 3D | mahzironrazak | FLUENT | 97 | December 28, 2020 23:09 |
How can I solve the mesh dependancy problem? | amirlachraf | Mesh Generation & Pre-Processing | 1 | July 20, 2019 02:57 |
How can I solve the mesh dependancy problem? | amirlachraf | FLUENT | 0 | June 16, 2019 04:59 |
Mesh, Solutions, Model, results | doneatlast | FLUENT | 0 | March 12, 2014 17:18 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 24, 2010 00:53 |
