Including the particle contact force in a DPM UDF
Old   January 15, 2020, 07:42
Default Including the particle contact force in a DPM UDF
Filippo Marchelli
filippo is on a distinguished road
I am trying to write a UDF using DEFINE_DPM_BODY_FORCE to modify the friction force acting on particles in CFD-DEM simulations in Fluent. To do this, I need to include in the UDF the normal contact force acting on the particle. However, I haven't found a way to do this in the guide. Is there a way to include the contact forces acting on a particle in a UDF? Thanks.
filippo is offline   Reply With Quote
Old   February 18, 2021, 11:45
Will Crawford-Jones
wcj1n18 is on a distinguished road
Hi, sorry this is a while ago now. Were you ever able to find out how to do this? You're using a DPM, i'm trying to do the same for 6DOF model, but unsure what the correct approach is. Did you have any success?
Cheers
wcj1n18 is offline   Reply With Quote
Old   February 18, 2021, 12:32
Filippo Marchelli
Cheers
Hi, no worries! I will have to disappoint you, I did not find a way to do this and in the end decided it was easier for me to try another program (MFIX). But I remember searching through a lot of different resources back then and consistently not finding anything, so perhaps it's just not possible. Good luck with your model!
Old   February 18, 2021, 13:01
Will Crawford-Jones
OK, thanks anyway. I will look around and think for a while longer before probably giving up and trying a different software!
cfd-dem, contact, define_dpm, friction, udf
DPM UDF particle position Tom FLUENT 8 July 25, 2015 13:30
Add Mass to a Particle with UDF (DPM) sega Fluent UDF and Scheme Programming 6 October 24, 2013 23:14
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari Main CFD Forum 0 August 19, 2010 04:01
DPM; particle seeded / deleted by UDF Laika FLUENT 6 January 23, 2006 00:40
