'bad suffix on number' when building udf function
Old   January 9, 2020, 10:18
Default 'bad suffix on number' when building udf function
Nguyen Duy Trong
ndtrong is on a distinguished road
Hi everyone,
I am trying to make an UDF function that can change timestep in unsteady simulation with Fluent.
Howeve, when I compile the UDF function with fluent, it show error like that:
..\..\src\timeStep.c(29): error C2059: syntax error: 'bad suffix on number'
The UDF file is as below:
#include "udf.h"
#include "unsteady.h"
DEFINE_DELTAT(myDeltaT, domain)
/*time step, flow time parameters*/
real timeStep, flowTime;
real cDeltaT;
real CFL;
real timeCheck;
/*variable to check velocity*/
real Ux, Uy, Uz, velCell;
/*variable to get minimum of volume*/
real volume;
/*common variable */
Domain *d;
Thread *t;
cell_t c;
/*Get domain*/
d = Get_Domain(1); /*Get the domain using ANSYS FLUENT utility*/
/*get timestep and flowtime*/
flowTime = RP_Get_Real("flow-time");
timeStep = RP_Get_Real("physical-time-step");
CFL = 0.1;
if(flowTime < 1.0d-5)
timeStep = 1.0d-6;
else
/*Loop over all cell threads in the domain*/
//minVol = 1.0d+9; /*Assign first value for minVol*/
timeCheck = 10.d0;
thread_loop_c(t,d)
/*Compute min cell's volume*/
begin_c_loop(c,t)
volume = C_VOLUME(c,t); /*get cell volume*/
Ux = C_U(c,t); /*get x component of velocity of current cell*/
Uy = C_V(c,t); /*get y component of velocity of current cell*/
Uz = C_W(c,t); /*get z component of velocity of current cell*/
velCell = sqrt(pow(Ux,2) + pow(Uy,2) + pow(Uz,2)); /*magnitude of velocity in current cell*/
cDeltaT = CFL * velCell/volume; /*compute timeStep in each cell volume*/
if(cDeltaT < timeCheck)
timeCheck = cDeltaT;
// cDeltaT = timeCheck;
end_c_loop(c,t)
timeStep = timeCheck;
Message("timestep %g \n",timeStep);
return timeStep;
/*get minimum of cell volume*/
It is appreciated if someone could explain to me the way to deal with this stuck.
I thank you very much,
ndtrong is offline   Reply With Quote
Old   January 9, 2020, 11:42
pakk will become famous soon enough
What is 1.0d-5?
Don't you mean 1.0e-5?
pakk is offline   Reply With Quote
Old   January 9, 2020, 22:45
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what fluent version do you use?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 10, 2020, 01:51
Nguyen Duy Trong
Originally Posted by pakk View Post
What is 1.0d-5?
Dear Pakk
I thank you very much for your suggestion. My problem is solved.
Old   January 10, 2020, 01:54
Nguyen Duy Trong
Dear AlexanderZ
I am using Fluent v19.2
Do you have any comments or suggestions for this?
Thanks
Old   January 10, 2020, 06:59
Alexander
v19.2 is parallel by default
you should organize your UDF to work in parallel
must be read on host, than transfer to nodes
Ansys Fluent Customization manual | Parallel Considerations
best regards
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 10:15
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
