How to edit a single phase UDF for a multiphase case?
Old   January 8, 2020, 05:02
Default How to edit a single phase UDF for a multiphase case?
Mat
mataus is on a distinguished road
In the first case (single phase case) liquid enters the tube and absorbs heat energy which is produced by the solid region. There is no phase change happening here. The following UDF is used to calculate the source term in single phase flow. The UDF works correctly.
#include "udf.h"
DEFINE_EXECUTE_AT_END(s_calculation)
Domain *d=Get_Domain(1);
int zone_id=6;
Thread *t = Lookup_Thread(d,zone_id);
cell_t c;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0)=C_T(c,t)*0.25;
end_c_loop(c,t)
DEFINE_SOURCE(energy, c, t, dS, eqn)
real x[ND_ND];
real source;
source =1680000*C_UDMI(c,t,0);
dS[eqn] = 0;
return source;
In second case, liquid enters the tube and undergoes phase change due heat addition. How to rewrite the above UDF for this multiphase case.
am getting some segmentation fault at the end of the first timestep when using the same UDF for multiphase flow.
I think i am unable to access the correct the solid zone.
mataus is offline   Reply With Quote
energy source udf, multiphase flow
Viscous dissipation UDF for multiphase DDPM (Divergence problem) bhargavbharathan FLUENT 0 November 30, 2016 13:23
Viscous dissipation UDF for multiphase DDPM bhargavbharathan Fluent Multiphase 0 November 30, 2016 13:17
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Two-phase/ Single phase mix flow Reza Main CFD Forum 1 August 6, 2003 07:36
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
