How to correct this UDF?
Old   January 3, 2020, 05:12
Default How to correct this UDF?
Mat
mataus is on a distinguished road
Hai...
Here is the simplified UDF for single-phase conjugate problem. The UDF calculates some values in the solid region.
DEFINE_EXECUTE_AT_END(source_calculation)
Domain *d=Get_Domain(1);
int zone_id=6;
Thread *t = Lookup_Thread(d,zone_id);
cell_t c;
thread_loop_c(t,d)
How to transform this UDF for the multiphase simulation problem? I need to do the same calculation in the solid region.
I am running transient-eulerian-boling-RPI model
It shows segmentation faults after the end first-time step when I run the simulation on multiphase with the above UDF.
I checked the zone id.
Cheers,
mataus is offline   Reply With Quote
Old   January 3, 2020, 05:18
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
not enough information
you may try to find examples on multiphase simulations in Ansys Fluent Customization manual
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 5, 2020, 22:24
Default how can i edit this udf
Mat
Thanks for the reply.
I can explain my simulation.
the domain consists of one solid and one fluid region.
a heat source is introduced in the solid region. the heat generated in the solid region is transferred to the flowing fluid and its temperature rises.
I have introduced a UDF( DEFINE_EXECUTE_AT_END) to calculate some values in the solid region.
the UDF works correctly and runs the simulation successfully.
#include "udf.h"
#define p 13.4
#define s 301.0024
#define m 4.12
DEFINE_EXECUTE_AT_END(pom_calculation)
int zone_id=6;
cell_t c;
real dt=CURRENT_TIMESTEP;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,1)=C_T(c,t)/s;
C_UDMI(c,t,3)=C_T(c,t)/p;
if (C_UDMI(c,t,3)>C_UDMI(c,t,1))
C_UDMI(c,t,2)=C_T(c,t)*m;
else
C_UDMI(c,t,2)=0;
C_UDMI(c,t,0)=C_UDMI(c,t,0)+(C_UDMI(c,t,2)*C_T(c,t ));
end_c_loop(c,t)
later I need to introduce a phase change of fluid (liq-vap) due to the heat transfer from the solid region. I tried the same UDF but it shows segmentation fault at the end first-time step.
I successfully simulate without the UDF.
how can I edit above udf to run in multiphase flow condition?
Old   January 6, 2020, 00:19
Alexander
code is correct
this code is not related to source, so it can't work the way, you've told
actually it does nothing
most likely, you didn't allocate memory for your user defined memories
you should put 4 in fluent GUI
best regards
Old   January 6, 2020, 01:07
Mat
thanks for your quick reply.
yes..you are correct the code does nothing with source term.
this is a simplified version of the UDF.
I have correctly allocated 4 memory locations.
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 03:39
udf for correct adjacent cell T Adam_PHD Fluent UDF and Scheme Programming 8 February 27, 2018 03:33
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 11:29
how to correct the error of (c) file after the compile of udf? mokrane FLUENT 0 April 23, 2015 14:40
how can I correct the udf? happyrabbit FLUENT 9 January 28, 2011 10:50
