January 2, 2020, 01:46 |
Error during initialization while using UDF
Dnyanesh Mirikar
Rep Power: 7 |
I want to write UDF for wall heat flux boundary condition. When I initialize the setup it gets closed (in both serial and parallel mode) with error
Node 0: Process 2532: Received signal SIGSEGV. MPI Application rank 0 exited before MPI_Finalize() My UDF code is #include "udf.h" //Heat generation model from Mahamud and Park (Lumped heat capacity model) DEFINE_HEAT_FLUX(Heat_gen,f,t,c0,t0,cid,cir) { #define I 24.984 #define EntCoeff -0.3 real Re; real T = C_T(f,t); real Td; //temperature in degree celcius real Qirr; real Qent; real Qt; Td=T-273.16; Re=12.407-0.5345*Td+0.0134*Td*Td-0.0001*Td*Td*Td; //T in degree celcius and Re in milli ohms Qirr=(I*I)*Re/1000; // Watt per metre square Qent=-I*(Td+273.16)*EntCoeff/1000; // Watt per metre square Qt=Qirr+Qent; } Please suggest a possible solution for this, I'm new to UDF. Thanks |
January 2, 2020, 23:49 |
Alexander
Rep Power: 34 |
#include "udf.h" #define I 24.984 #define EntCoeff -0.3 //Heat generation model from Mahamud and Park (Lumped heat capacity model) DEFINE_HEAT_FLUX(Heat_gen,f,t,c0,t0,cid,cir) { real Re; real T = C_T(f,t); real Td; //temperature in degree celcius real Qirr; real Qent; real Qt; Td=T-273.16; Re=12.407-0.5345*Td+0.0134*Td*Td-0.0001*Td*Td*Td; //T in degree celcius and Re in milli ohms Qirr=(I*I)*Re/1000; // Watt per metre square Qent=-I*(Td+273.16)*EntCoeff/1000; // Watt per metre square Qt=Qirr+Qent; }
best regards ****************************** press LIKE if this message was helpful |
heat flux fluent udf, udf |
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 22:28 |
Error code: 126 when loading parallel UDF | Coop | Fluent UDF and Scheme Programming | 0 | July 13, 2018 08:33 |
UDF - Error while Solution Initialization | QuocHung_Phan | Fluent UDF and Scheme Programming | 2 | October 11, 2013 03:03 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 11:29 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
