C_udsi_g
Old   December 27, 2019, 17:51
Default C_udsi_g
Andrea
Andrea159357 is on a distinguished road
i'm trying to calculate the gradient of the WALL SHEAR STRESS but i'm facing a problem.
It's a semicirular domain in 3D with a cylinder in the middle. At the Inlet, the left side, velocity is imposed, Outflow is on the right, Bottom and Cylinder is noslip while top is freeslip.
i used DEFINE_ADJUST macro to calculate WSS of the wall face and then i allocated the WSS in the cell adjacent to that face thanks to UDMI(0).
Then i set UDSI(0) = UDMI(0).
UDMI(1) = UDSI_G(0)[0]
UDMI(2) = UDSI_G(0)[1]
The problem, in my opinion, is that the gradient is affected by numerical error
Here is the code:
#include "udf.h"
#define ID_ground 6
DEFINE_ON_DEMAND(SELECTING_CELL_MEMORY)
Domain *d;
Thread *t;
cell_t c;
d=Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0)=0; /*tau_wall*/
C_UDMI(c,t,1)=0; /*D_SQRT(tau_wall)_DX*/
C_UDMI(c,t,2)=0; /*D_SQRT(tau_wall)_DY*/
end_c_loop(c,t)
DEFINE_ADJUST(UDS0, d)
Thread *tc, *t0;
cell_t c0;
face_t f;
tc = Lookup_Thread(d,ID_ground);
begin_f_loop(f,tc)
real A[ND_ND];
F_AREA(A,f,tc);
real area = NV_MAG(A);
real tau_wall = NV_MAG(F_STORAGE_R_N3V(f,tc, SV_WALL_SHEAR))/area;
c0=F_C0(f,tc);
t0=THREAD_T0(tc);
C_UDMI(c0,t0,0) = tau_wall;
C_UDSI(c0,t0,0) = C_UDMI(c0,t0,0);
C_UDMI(c0,t0,1) = C_UDSI_G(c0,t0,0)[0];
C_UDMI(c0,t0,2) = C_UDSI_G(c0,t0,0)[1];
end_f_loop(f,tc)
iThe gradient problem is showed in the following images: WSS, D_WSS_DX, D_WSS_DY:
Can someone help me?
THANKS
Andrea159357 is offline   Reply With Quote
Old   December 30, 2019, 00:13
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you've defined UDSI only I 1 cell layer near the wall boundary, isnt it?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 30, 2019, 05:25
Andrea
Exactly, I'm studing scouring of the seabed. That's the quantity of material removed from the ground by the sea current.
Old   December 30, 2019, 21:27
Alexander
may be you should define USDI = 0 everywhere first.
also it could be useful to switch off 'node values' in contours, so you can see fields without interpolation
best regards
Old   December 30, 2019, 22:35
Andrea
Since UDM=0 is initialized in EXECUTE_ON_DEMAND, UDM(c0,t0) is overwritten in the cell near boundary, UDS is 0 everywhere and has a value just near wall. When i inspect contour i usually turn off nodes value and see just cell values.
Could it be that the gradient is wrong since i didn't assign nodes and faces but just cell value?
Seems strange because i'm not using GreenGaus node based but Least squared.
I really don't know why this behavior.
Have you some experience in DEFINE_UDS_FLUX? maybe i can avoid C_UDSI_G define a new flux function and solving the scalar without assign it in the wall cells
Old   January 2, 2020, 00:35
Alexander
I don't think you should assign nodes and faces values
Is your simulation is steady state? How do you calculate UDS?
best regards
Old   January 2, 2020, 04:00
Andrea
Yes, is a steady state calculation.
I want to solve the divergence of WALL SHEAR STRESS times friction velocity, (div(WSS*U_star)).
First i tryed to allocate the value of (D(tau_wall)/DX * U_star_x + tau_wall*D(U_star_x)/DX + D(tau_wall)/DY * U_star_y + tau_wall*D(U_star_y)/DY) directly into cell C0. Since the gradient of tau_wall through the definition of UDSI = tau_wall suffers of numerical error due to oscillations, i tryed to solve UDS imposing 0 as diffusivity coefficient and redefine UDS flux.
UDS FLUX is defined as:
u_star_x = U/sqrt(U^2+V^2),
u_star_y = V/sqrt(U^2+V^2),
u_star_z = 0, at the c0 cell adjacent to wall and u,v,w= 0 everywhere else but it is not working. When i solve UDSI en error of floating point exception pops up.
!!! C_UDMI(c0,t0,0) = tau_wall !!! define in UDF previously posted
#include "udf.h"
#define rho 1000 /* Water Density ; */
DEFINE_UDS_FLUX(UDS1_Q_FLUX,f,t,i)
cell_t c0, c1 = -1;
Thread *t0, *t1 = NULL;
real NV_VEC(psi_vec), NV_VEC(A), flux = 0.0;
c0 = F_C0(f,t);
t0 = F_C0_THREAD(f,t);
F_AREA(A, f, t);
/* If face lies at domain boundary, use face values; */
/* If face lies IN the domain, use average of adjacent cells. */
if (BOUNDARY_FACE_THREAD_P(t)) /*Most face values will be available*/
NV_DS(psi_vec, =, C_UDMI(c0,t0,0)*F_U(f,t)/sqrt(F_U(f,t)*F_U(f,t) + F_V(f,t)*F_V(f,t)), C_UDMI(c0,t0,0)*F_V(f,t)/sqrt(F_U(f,t)*F_U(f,t) + F_V(f,t)*F_V(f,t)), 0, *, rho);
flux = NV_DOT(psi_vec, A); /* flux through Face */
else
c1 = F_C1(f,t); /* Get cell on other side of face */
t1 = F_C1_THREAD(f,t);
NV_DS(psi_vec, =, C_UDMI(c0,t0,0)*C_U(c0,t0)/sqrt(C_U(c0,t0)*C_U(c0,t0) + C_V(c0,t0)*C_V(c0,t0)) , C_UDMI(c0,t0,0)*C_V(c0,t0)/sqrt(C_U(c0,t0)*C_U(c0,t0) + C_V(c0,t0)*C_V(c0,t0)) , 0 ,*,rho);
NV_DS(psi_vec, +=, C_UDMI(c1,t1,0)*C_U(c1,t1)/sqrt(C_U(c1,t1)*C_U(c1,t1) + C_V(c1,t1)*C_V(c1,t1)) , C_UDMI(c0,t0,1)*C_V(c1,t1)/sqrt(C_U(c1,t1)*C_U(c1,t1) + C_V(c1,t1)*C_V(c1,t1)) , 0 ,*,rho);
flux = NV_DOT(psi_vec, A)/2.0; /* Average flux through face */
return flux;
Old   January 10, 2020, 05:57
Andrea
I've found the problem. UDF was not write for parallel usage.
The numerical error of the gradient is located at the interface of the partition of domain passed to the different cores
Old   January 10, 2020, 06:52
Alexander
so what did you change?
if loop over faces is embedded into DEFINE_UDS_FLUX(UDS1_Q_FLUX,f,t,i) macro?
best regards
Old   January 10, 2020, 07:34
Andrea
No, DEFINE_UDS_FLUX was an alternative to avoid numerical error in DEFINE_ADJUST.
I'm studying how to parallelize my UDF (DEFINE_ADJUST to avoid this problem).
I think that the gradient is counted two times because of mirrores cells at boundary (Exterior cells).
When i will come up with a solution i'll post a parallelized version of the UDF for define Adjust
Old   January 12, 2020, 19:35
Alexander
you may check ansys fluent customization manual -> parallel consideration
best regards
