There was an error in the UDF definition inlet speed
Old   December 26, 2019, 21:35
Default There was an error in the UDF definition inlet speed
Yeyue
Yeyue is on a distinguished road
Velocity changes with the temperature of the flow field. I don't know how the UDF calls the fluent temperature field. UDF programming is as follows, import fluent prompts the error as follows, I hope to get your help ~Thank you.
#include"udf.h"
DEFINE_PROFILE(in_x_velocity,cell,thread)
real x[ND_ND];
real y;
real temp=C_T(cell,thread);
real n;
real y;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x,f,thread);
y=x[1];
n=5.7171-0.009*temp;
y=4.7*10e-6*exp(6800/temp);
real yy;
yy=pow(m,1/n);
{ if(temp>291.15)
F_PROFILE(f,cell,thread)=0.02*(n+3)/(n+1)*(1-pow((y/0.010435),(n+1)));
else
F_PROFILE(f,cell,thread)=0.02*(n+3)/(n+1)*(1/(4*pow(1.52,n)+(n+3)*(5.964-0.02*temp)*100*1.52/yy)*(4*pow(1.52,n)/y*(1-pow((y/0.010435),(n+1)))+2(n+1)*(5.964-0.02*temp)*100*1.52/yy*(1-pow((y/0.010435),2))
end_f_loop(f,thread)
cpp -I"D:\ansys\ANSYS Inc\v150\fluent\fluent15.0.0/src" -I"D:\ansys\ANSYS Inc\v150\fluent\fluent15.0.0/cortex/src" -I"D:\ansys\ANSYS Inc\v150\fluent\fluent15.0.0/client/src" -I"D:\ansys\ANSYS Inc\v150\fluent\fluent15.0.0/multiport/src" -I. -DUDFCONFIG_H
"<C:/Users/ADMINI~1/AppData/Local/Temp/udfconfig-30856-node1.h>" "C:/Users/ADMINI~1/AppData/Local/Temp/Velocity1.c.30856.1.c"
Error: C:/Users/ADMINI~1/AppData/Local/Temp/Velocity1.c.30856.1.c: line 6: non-integer subscript expression: pointer to structure.
Yeyue is offline   Reply With Quote
Old   December 26, 2019, 21:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you must compile following
#include "udf.h"
#include "math.h"
DEFINE_PROFILE(in_x_velocity,t, i)
real x[ND_ND];
real y;
real temp;
real n;
real y;
real yy;
face_t f;
begin_f_loop(f,t)
	temp=F_T(f,t)
	F_CENTROID(x,f,t);
	y=x[1];
	yy=pow(m,1/n);
	{ if(temp>291.15)
	F_PROFILE(f,t,i)=0.02*(n+3)/(n+1)*(1-pow((y/0.010435),(n+1)));
	else
	F_PROFILE(f,t,i)=0.02*(n+3)/(n+1)*(1/(4*pow(1.52,n)+(n+3)*(5.964-0.02*temp)*100*1.52/yy)*(4*pow(1.52,n)/y*(1-pow((y/0.010435),(n+1)))+2(n+1)*(5.964-0.02*temp)*100*1.52/yy*(1-pow((y/0.010435),2))
end_f_loop(f,t)
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 26, 2019, 22:51
Default udf
Yeyue
Hello, I modified it according to your comments, but the following problems will still occur, and I look forward to your reply.
#include"udf.h"
#include"math.h"
DEFINE_PROFILE(in_x_velocity,thread,index)
real x[ND_ND];
real y;
real n;
real yy;
real w;
real temp;
face_t f;
Thread *t;
temp=F_T(f,t);
y=x[1];
yy=0.0000047*exp(6800/temp);
w=pow(yy,1/n);
{ if(temp>291.15)
F_PROFILE(f,thread,index)=0.02*(n+3)/(n+1)*(1-pow((y/0.010435),(n+1)));
else if(temp>=288.15&&temp>=291.15)
F_PROFILE(f,thread,index)=0.02*(n+3)/(n+1)*(1/(4*pow(1.52,n)+(n+3)*(5.964-0.02*temp)*100*1.52/w)*(4*pow(1.52,n)/yy*(1-pow((y/0.010435),(n+1)))+2(n+1)*(5.964-0.02*temp)*100*1.52/w*(1-pow((y/0.010435),2))
"<udfconfig.h>" "C:\Users\Administrator\Desktop\UDF\Velocity1. c"
Error: udfconfig.h: line 16: parse error.
best regards
Old   December 27, 2019, 02:06
Alexander
https://www.youtube.com/watch?v=OPfgkORSESQ
best regards
Old   December 27, 2019, 02:28
Yeyue
I can't open the website you sent. Can you help me modify this program if you are convenient? Thank you very much.
best regards
Old   December 27, 2019, 05:00
Alexander
make working directory
put there your case file and UDF file
open VIsual Studio console and run Fluent from this console
compile UDF, load UDF
best regards
fluent, udf, velocity
Disappearing mass when using udf inlet profile divergence Fluent UDF and Scheme Programming 5 January 2, 2021 15:56
how to put udf inlet velocity and udf outlet pressure in fluent raminostadi Fluent UDF and Scheme Programming 4 July 3, 2017 07:43
UDF profile: Fluent method for coupling inlet and outlet I-mech Fluent UDF and Scheme Programming 0 May 10, 2014 11:36
"Closing" a pressure inlet via UDF? dave88 Fluent UDF and Scheme Programming 0 August 27, 2013 19:14
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 13:32
