How to calculate the number of if conditions executed in a fluent udf?
Like Tree7Likes
Old   January 14, 2020, 03:38
South Australia
Shubhamp is on a distinguished road
After putting the suggested lines in the if condition am getting the same output.
#include "udf.h"
real sensor_temperature = 315.15
DEFINE_EXECUTE_AT_END(tsensor)
real x[ND_ND];
real xc,yc,zc,nt;
real sensor_temperature = 0.0; /* had to re-initialize again otherwise the sensor_temperature value was increasing after each timestep.*/
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
nt=0.0;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_CENTROID(x,c,t);
xc = 0.000000;
yc = 0.000000;
zc = 1.500000;
if ((xc >= -0.468547) && (xc <= 0.493969))
if ((yc >= -0.51177) && (yc <= 0.428963))
if ((zc >= 1.34611) && (zc <= 1.59948))
xc = x[0];
yc = x[1];
zc = x[2];
sensor_temperature = sensor_temperature + C_T(c,t);
nt=nt+1.0;
end_c_loop(c,t)
# if RP_NODE
nt = PRF_GRSUM1(nt);
sensor_temperature = PRF_GRSUM1(sensor_temperature);
# endif
sensor_temperature /= nt;
Message0 ("xc = %f\n",xc);
Message0 ("yc = %f\n",yc);
Message0 ("zc = %f\n",zc);
Message0 ("nt = %f\n",nt);
Message0("sensor_temperature = %f\n",sensor_temperature);
output:
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 321814.000000
sensor_temperature = 315.150000
Shubhamp is offline   Reply With Quote
Old   January 14, 2020, 22:42
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
compile code, read errors
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 14, 2020, 23:46
South Australia
My mistake, actually the mentioned output values were during the simulation (compiled without any errors) i.e. before the first iteration and after the first solution convergence step.
Thanks
Old   January 15, 2020, 01:59
Alexander
code above definitely has errors
at least you can't define any variable twice
compile code.
if you selected 92 cells using fluent adaptation tool, you expect to get nt=92
work on it
best regards
Old   January 16, 2020, 19:30
South Australia
I have worked on the coordinate values and received 92 cells as desired. However, now the inlet velocity is not altering from 0.051 to 0 when tavg_abr > sensor_temperature. I have mentioned the problem beside the line in the code. Your suggestion is highly required.
Thanks
#include "udf.h"
real tavg_abr;
real UDSavg_abr;
real sensor_temperature;
int if_number = 0;
real x[ND_ND];
real xc,yc,zc,nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
nt=0.0;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_CENTROID(x,c,t);
xc = x[0];
yc = x[1];
zc = x[2];
if ((xc >= -0.468547) && (xc <= 0.523969))
if ((yc >= -0.51177) && (yc <= 0.468963))
if ((zc >= 1.34611) && (zc <= 1.63948))
nt=nt+1.0;
end_c_loop(c,t)
# if RP_NODE
# endif
DEFINE_EXECUTE_AT_END(avg_inlet_tempandUDS)
int ID = 8;
Domain *d;
face_t f;
real area[ND_ND];
real a;
real area_tot = 0.0;
real tavg_abr = 0.0;
real UDSavg_abr = 0.0;
Thread *tf;
d = Get_Domain(1);
tf = Lookup_Thread(d,ID);
begin_f_loop(f,tf)
F_AREA(area,f,tf);
a = NV_MAG(area);
area_tot += a;
tavg_abr += F_T(f,tf)*a;
UDSavg_abr += F_UDSI(f,tf,0)*a;
end_f_loop(f,tf)
#if RP_NODE
area_tot = PRF_GRSUM1(area_tot);
tavg_abr = PRF_GRSUM1(tavg_abr);
UDSavg_abr = PRF_GRSUM1(UDSavg_abr);
#endif
tavg_abr /= area_tot;
UDSavg_abr /= area_tot;
Message0("tavg_abr = %f UDSavg_abr = %f area_tot = %f\n",tavg_abr, UDSavg_abr, area_tot);
DEFINE_PROFILE(velocity,t,i)
real velocity;
face_t f;
if ((tavg_abr < sensor_temperature))
velocity = 0.051;
total_fan_time++;
else
velocity = 0.0;
begin_f_loop(f,t)
F_PROFILE(f,t,i) = velocity;
end_f_loop(f,t)
DEFINE_ON_DEMAND(get_if_number)
Message0("******** int if_number = %d**************\n",if_number);
output:
tavg_abr = 315.147083 UDSavg_abr = 0.007000 area_tot = 18.720000
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 93.000000
step flow-time report-def-0 report-def-0 flow-time
178 3.5600e+02 -9.5644e-01 9.5472e-01 3.5600e+02 /* the volume flow rate is okay here as it is obeying the if condition in DEFINE_PROFILE macro for velocity */
Updating solution at time level N...
done.
tavg_abr = 315.156389 UDSavg_abr = 0.007000 area_tot = 18.720000
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 93.000000
179 3.5800e+02 -9.5644e-01 9.5472e-01 3.5800e+02 /* However here the volume flow rate should be zero as velocity should be zero according to DEFINE_PROFILE macro but it is not. What can be done to achieve this? Is the code not entering the 'else' condition?
******** int if_number = 179 ************** /* This is the iteration number. Can anything be done to obtain the number of timesteps instead of iterations? */
Old   January 21, 2020, 18:29
South Australia
Any suggestions on how to correct the above code?
Help is highly appreciated.
Thanks
Old   January 22, 2020, 02:22
Alexander
total_fan_time is not defined in your code
if_number is not calculated anywhere in code
all other parts should work with no errors
check velocity value on inlet boundary (where you've applied UDF)
best regards
Old   January 22, 2020, 03:28
South Australia
Apologies for the typo error. I have attached the corrected code below. But receiving the same output as mentioned below against the code. Is there a way to obtain the number of time-steps instead of iterations. The velocity at the inlet boundary remains 0.051 m/s even when tavg_abr >= sensor_temperature. Please suggest if anything can be done.
Thanks
#include "udf.h"
real tavg_abr;
real UDSavg_abr;
int if_number = 0;
real x[ND_ND];
real xc,yc,zc,nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
nt=0.0;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_CENTROID(x,c,t);
xc = x[0];
yc = x[1];
zc = x[2];
nt=nt+1.0;
end_c_loop(c,t)
# if RP_NODE
# endif
int ID = 8;
Domain *d;
face_t f;
real area[ND_ND];
real a;
Thread *tf;
d = Get_Domain(1);
begin_f_loop(f,tf)
F_AREA(area,f,tf);
a = NV_MAG(area);
area_tot += a;
end_f_loop(f,tf)
#if RP_NODE
#endif
real velocity;
face_t f;
velocity = 0.051;
if_number++;
else
velocity = 0.0;
begin_f_loop(f,t)
end_f_loop(f,t)
output:
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 93.000000
done.
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 93.000000
Old   January 22, 2020, 04:01
Alexander
calculate if_number using DEFINE_EXECUTE_AT_END macro
you may use messages to check if you inside condition or outside
check VELOCITY on boundary, not mass flow rate, or anything else
best regards
Old   January 22, 2020, 05:28
South Australia
Thanks for suggestions to include DEFINE_EXECUTE_AT_END to get the if number. It is working now. I used the Facet average of the velocity magnitude at inlet and outlet but velocity is not entering the "tavg_abr >= sensor_temperature" and it is 0.051 always.
Thanks
Old   January 22, 2020, 05:49
Alexander
make velocity global variable
put if ((tavg_abr < sensor_temperature)) in execute_at_end macro
best regards
Old   January 22, 2020, 06:44
South Australia
I did the same. And now i am getting the number of if_number at every timesteps. But the velocity value is remaining same even if tavg_abr > sensor_temperature.
Thanks
Old   January 22, 2020, 20:48
South Australia
I have attached the code with velocity as a global variable. Even then also the report-def-0 (volume flow rate) is not changing. I have included a line to show if inlet is on or off but it is also showing inlet is on even if the condition is not met. Please suggest if anything can be done.
Thanks
#include "udf.h"
real velocity;
real tavg_abr;
real UDSavg_abr;
int if_number = 0;
real x[ND_ND];
real xc,yc,zc,nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
nt=0.0;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_CENTROID(x,c,t);
xc = x[0];
yc = x[1];
zc = x[2];
nt=nt+1.0;
end_c_loop(c,t)
# if RP_NODE
# endif
int ID = 8;
Domain *d;
face_t f;
real area[ND_ND];
real a;
Thread *tf;
d = Get_Domain(1);
begin_f_loop(f,tf)
F_AREA(area,f,tf);
a = NV_MAG(area);
area_tot += a;
end_f_loop(f,tf)
#if RP_NODE
#endif
DEFINE_PROFILE(velocity1,t,i)
face_t f;
if ((tavg_abr <= sensor_temperature))
#if !RP_HOST
Message0("inlet is on");
#endif
velocity = 0.051;
else
#if !RP_HOST
Message0("inlet is off");
#endif
velocity = 0.0;
begin_f_loop(f,t)
end_f_loop(f,t)
DEFINE_EXECUTE_AT_END(get_if_number)
if (tavg_abr <= sensor_temperature)
if_number++;
Message0("******** int if_number = %d **************\n",if_number);
output:
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 93.000000
inlet is on step flow-time report-def-0 report-def-0 flow-time
done.
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 93.000000
******** int if_number = 180 **************
179 3.5800e+02 -9.5644e-01 9.5472e-01 3.5800e+02 /* report-def-0 should be 0 here as tavg_abr >sensor_temperature */
Old   January 23, 2020, 00:13
Alexander
change last 2 functions
face_t f;
begin_f_loop(f,t)
end_f_loop(f,t)
velocity = 0.051;
Message0("++++++++ inlet is on ++++++\n");
if_number++;
else
{velocity = 0.0;
Message0("------- inlet is off -------\n");
best regards
Old   January 23, 2020, 01:24
South Australia
Thanks for the suggestions. I incorporated your changes but receiving the same message i.e. inlet is on even when tavg_abr > sensor_temperature. I had also tried with DEFINE_ADJUST macro but getting the same result. Could there be any other reason why it is not entering the "else" loop? Your suggestions are highly required.
Thanks
#include "udf.h"
real velocity;
real tavg_abr;
real UDSavg_abr;
int if_number = 0;
real x[ND_ND];
real xc,yc,zc,nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
nt=0.0;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_CENTROID(x,c,t);
xc = x[0];
yc = x[1];
zc = x[2];
nt=nt+1.0;
end_c_loop(c,t)
# if RP_NODE
# endif
int ID = 8;
Domain *d;
face_t f;
real area[ND_ND];
real a;
Thread *tf;
d = Get_Domain(1);
begin_f_loop(f,tf)
F_AREA(area,f,tf);
a = NV_MAG(area);
area_tot += a;
end_f_loop(f,tf)
#if RP_NODE
#endif
face_t f;
begin_f_loop(f,t)
end_f_loop(f,t)
velocity = 0.051;
if_number++;
else
{velocity = 0.0;
Output:
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 2.000000
done.
xc = -2.738164
yc = 1.462940
zc = 4.978388
nt = 2.000000
179 3.5800e+02 -9.5644e-01 9.5472e-01 3.5800e+02 /* report-def-0 is still not 0 here when tavg_abr > sensor_temperature */
Old   January 23, 2020, 03:22
Alexander
I've told you, you can't define variable twice in code but
#include "udf.h"
real velocity;
real tavg_abr;
real UDSavg_abr;
int if_number = 0;
real x[ND_ND];
real xc,yc,zc,nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
nt=0.0;
wtf?
tobe
#include "udf.h"
real velocity;
real tavg_abr;
real UDSavg_abr;
int if_number = 0;
real x[ND_ND];
real xc,yc,zc,nt;
cell_t c;
Domain *d;
Thread *t;
d = Get_Domain(1);
nt=0.0;
check all your global variables
put messages everywhere and check which value you have on each step, find the place, where code doesn't work as you expect, fix it
Shubhamp likes this.
best regards
Old   January 23, 2020, 19:19
South Australia
Apologies for not making that correction. Now the code works perfectly after changing the lines according to your suggestions.
Many Many thanks for the long discussion.
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
How to use UDF to get the Global courant number at time in fluent 14.0? fangdian Fluent UDF and Scheme Programming 1 August 18, 2015 20:33
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
