Changing devolatilisation Arrhenius parameters via UDF? |
Rep Power: 6 ![]() |
Hi all,
I am currently wondering about how I can change the Arrhenius parameters of the devolatilisation of a particle based on the particle diameter. I don't really want to re-write the whole devolatilisation law with mass and energy balances, since that seems like overkill. The pseudo-code looks like this: /******* UDF that models custom Arrhenius parameters for each particle **************/ #include "udf.h" DEFINE_DPM_LAW(variable_Arrhenius, p, ci){ if (0 < P_DIAM(p) < 100) A = 1; E = 100; else if ( 100 < P_DIAM(p) < 500) A = 2; E = 200; else A = 3; E = 300; VaporizationLaw(p); } But I can not seem to find a way to edit A and E? Any help would be appreciated. Cheers! |
Alexander
Rep Power: 34 ![]() ![]() |
share your case, I'll try to find something
best regards ****************************** press LIKE if this message was helpful |
Hey Alexander, thanks for the quick reply. I am not able to share the real case, but in general it's just a simple tube with a particle injection at one end. I have a representative simplified case at hand, however I seem not to be able to upload it here due to file restrictions. The geometry and injections are irrelevant though, and the problem can be found in any combustion case.
Alexander
I dont know how to set up this problem correctly. No experience, cant help you without case
arrhenius, devolatilisation, udf |
how to plot graph for output parameters using UDF? | ned.musab | Fluent UDF and Scheme Programming | 0 | October 29, 2017 07:23 |
Need help in writing UDF for an oscillating airfoil to get Output parameters | ned.musab | FLUENT | 0 | October 27, 2017 11:21 |
How to modify Arrhenius rate parameters in Fluent ?? | Kashif123 | FLUENT | 0 | October 25, 2016 21:59 |
changing scheme variable with UDF? | Wagemakers | FLUENT | 17 | September 30, 2015 14:34 |
udf or Parameters in fluent..plz help.. | nitman118 | Fluent UDF and Scheme Programming | 0 | June 6, 2013 06:51 |
