fluent udf lines for acessing the first cell of a given boundary zone
Old   November 28, 2019, 18:17
Default fluent udf lines for acessing the first cell of a given boundary zone
Alexandre M S Costa
amscosta is on a distinguished road
Hi All,
I am trying to access the first cell of a given plane boundary zone, instead of using
the begin_f_loop(f,t) (that does the job but loops over all faces of the boundary zone).
Any piece of advice for the udf gurus are very welcome.
Thanks
Alex
amscosta is offline   Reply With Quote
Old   November 29, 2019, 01:05
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I dont know the way to access face/cell without loops
you can do following
n = 0;
begin_f_loop(f,t)
{ if (n<1)
   { //do whatever you want}
   n++;
{ //do whatever you want} will be executed once
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
first cell
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 09:26
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
