error c2440 during compiling of udf in fluent
Old   November 27, 2019, 07:41
Smile error c2440 during compiling of udf in fluent
Rajasekar
Rajasekar_K is on a distinguished road
Hi I am trying to compile the DPM_HEAT_MASS for multicomponent UDF(pasted at bottom of this question) given by ANSYS, when I am trying to compile it is showing the following error(given after the udf) at the line highlighted in magenta. kindly help me to solve this issue.
UDF for defining the heat and mass transport for
multicomponent particle vaporization
#include "udf.h"
DEFINE_DPM_HEAT_MASS(multivap,p,Cp,hgas,hvap,cvap_ surf,Z,dydt,dzdt)
int ns;
Material *sp;
real dens_total = 0.0; /* total vapor density*/
real P_total = 0.0; /* vapor pressure */
int nc = TP_N_COMPONENTS(p); /* number of particle components */
Thread *t0 = P_CELL_THREAD(p); /* thread where the particle is in*/
Material *gas_mix = THREAD_MATERIAL(DPM_THREAD(t0, p)); /* gas mixture material */
Material *cond_mix = P_MATERIAL(p); /* particle mixture material*/
cphase_state_t *c = &(p->cphase); /* cell information of particle location*/
real molwt[MAX_SPE_EQNS]; /* molecular weight of gas species */
real Tp = P_T(p); /* particle temperature */
real mp = P_MASS(p); /* particle mass */
real molwt_bulk = 0.; /* average molecular weight in bulk gas */
real Dp = DPM_DIAM_FROM_VOL(mp / P_RHO(p)); /* particle diameter */
real Ap = DPM_AREA(Dp); /* particle surface */
real Pr = c->sHeat * c->mu / c->tCond; /* Prandtl number */
real Nu = 2.0 + 0.6 * sqrt(p->Re) * pow(Pr, 1./3.); /* Nusselt number */
real h = Nu * c->tCond / Dp; /* Heat transfer coefficient*/
real dh_dt = h * (c->temp - Tp) * Ap; /* heat source term*/
dydt[0] += dh_dt / (mp * Cp);
dzdt->energy -= dh_dt;
mixture_species_loop(gas_mix,sp,ns)
molwt[ns] = MATERIAL_PROP(sp,PROP_mwi); /* molecular weight of gas
species */
molwt_bulk += c->yi[ns] / molwt[ns]; /* average molecular weight */
/* prevent division by zero */
molwt_bulk = MAX(molwt_bulk,DPM_SMALL);
for (ns = 0; ns < nc; ns++)
int gas_index = TP_COMPONENT_INDEX_I(p,ns); /* gas species index of
vaporization */
if( gas_index >= 0 )
/* condensed material */
Material * cond_c = MIXTURE_COMPONENT(cond_mix, ns);
/* vaporization temperature */
real vap_temp = MATERIAL_PROP(cond_c,PROP_vap_temp);
/* diffusion coefficient */
real D = MATERIAL_PROP_POLYNOMIAL(cond_c, PROP_binary_diffusivity,
c->temp);
/* Schmidt number */
real Sc = c->mu / ( c->rho * D );
/* mass transfer coefficient */
real k = (2. + 0.6 * sqrt(p->Re) * pow(Sc, 1./3.)) * D / Dp;
/* bulk gas concentration (ideal gas) */
real cvap_bulk = c->pressure / UNIVERSAL_GAS_CONSTANT / c->temp
* c->yi[gas_index] / molwt_bulk / solver_par.molWeight[gas_index];
/* vaporization rate */
real vap_rate = k * molwt[gas_index] * Ap
* (cvap_surf[ns] - cvap_bulk);
/* no vaporization below vaporization temperature, no condensation */
if (Tp < vap_temp || vap_rate < 0.0)
vap_rate = 0.;
dydt[1+ns] -= vap_rate;
dzdt->species[gas_index] += vap_rate;
/* dT/dt = dh/dt / (m Cp)*/
dydt[0] -= hvap[gas_index] * vap_rate / ( mp * Cp );
/* gas enthalpy source term */
dzdt->energy += hgas[gas_index] * vap_rate;
P_total += cvap_surf[ns];
dens_total += cvap_surf[ns] * molwt[gas_index];
/* multicomponent boiling */
P_total *= Z * UNIVERSAL_GAS_CONSTANT * Tp;
if (P_total > c->pressure && dydt[0] > 0.)
real h_boil = dydt[0] * mp * Cp;
/* keep particle temperature constant */
dydt[0] = 0.;
if (gas_index >= 0)
real boil_rate = h_boil / hvap[gas_index] * cvap_surf[ns] *
molwt[gas_index] / dens_total;
/* particle component mass source term */
dydt[1+ns] -= boil_rate;
/* fluid species source */
dzdt->species[gas_index] += boil_rate;
/* fluid energy source */
dzdt->energy += hgas[gas_index] * boil_rate;
ERROR:
udf_names.c and user_nt.udf files in 2ddp_node are upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v194\fluent"\fluent19.4.0\sr c\udf\makefile_nt.udf "libudf\win64\2ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\2ddp_node")# Generating ud_io1.h
tobechecked.cpp
..\..\src\tobechecked.cpp(18): error C2440: 'initializing': cannot convert from 'cphase_state_t **' to 'cphase_state_t *'
..\..\src\tobechecked.cpp(18): note: Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast
Done.
Rajasekar_K is offline   Reply With Quote
Old   November 28, 2019, 03:12
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
on my machine i have warning only
..\..\src\test_delete.c(18) : warning C4047: 'initializing' : 'cphase_state_t *' differs in levels of indirection from 'cphase_state_t **'
with small change
cphase_state_t *c = (p->cphase); /* cell information of particle location*/
no warning comes out, however, I'm not sure If it is possible to remove & or not
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 28, 2019, 05:02
Rajasekar
Thanks alexanderZ sir, now it is compiling without any warning in my machine, I have to check with the simulatiom now.. Thanks
dpm fluent model, evaporation of droplet
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 03:48
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Error while compiling udf in fluent 13.0.0 siddharth12 FLUENT 0 December 3, 2013 17:46
compiling my UDF Seyed Farid Hosseinizadeh FLUENT 22 February 14, 2006 11:19
