Getting Iteration Number in steady state problem |
AminR
Rep Power: 0 ![]() |
Hi everyone,
I'm solving a non-Newtonian flow problem in fluent. I wrote a udf for different boundary conditions and viscosity model. Unfortunately, when I'm using all of them, I cannot get solution (floating point at start). Interesting enough, when I use constant viscosity, it works perfectly. then after 10 or 20 iteration I select my viscosity model in material>Fluid and it converges. Convergence is still slow. So I was looking for a way to get the iteration number in udf and apply my viscosity model slowly after every iteration. my model: -non Newtonian fluid flow with heat transfer (viscous dissipation) - both variable (udf defined) velocity and temperature profile at inlet - viscosity model: Carreau-Yasuda with temperature dependency |
non-newtonian model, udf;fluent;viscosity |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
