November 7, 2019, 06:40 |
UDF to read a set of data?
Josh
Rep Power: 7 |
Hi everyone,
I have a txt document like this: time velocity 0 0 0.1 1.3 0.2 1.7 0.3 2.5 ..and so on. My dataset unfortunately is not so easy, in fact I have a periodic function that has a pretty irregular velocity in time. The problem is that I have to impose this velocity as a UDF on a wall of my domain but I cannot find a function to properly fits those data. So my question: is there a way to write a UDF to read this dataset to impose the value of velocity for the timestep? Thanks |
November 7, 2019, 06:54 |
Rep Power: 9 |
You need to load your data into a C array and use a search function to get them.
November 7, 2019, 07:02 |
Josh
Rep Power: 7 |
November 7, 2019, 07:20 |
Rep Power: 9 |
November 7, 2019, 07:24 |
#5 | |
Josh
Rep Power: 7 |
The problem is to write in the udf language. I have the udf manual but I cannot do it... |
November 7, 2019, 07:46 |
Rep Power: 9 |
You should be aware that UDF is a C code in which you load the udf header to access some of the Fluent utilities.
What I want to say is that that you can write a dummy C function which reads your file and transfers the values to a global defined array: Code:
#include "udf.h" double** data; void build_table() { // code to allocate data from file to the variable "data" } Code:
DEFINE_ON_DEMAND(read_file) { build_table(); } This creates you an "execute on demand" function that allows the remaining part of your code to read the values in the array. |
udf, udf and programming, udf code, udf customize |
UDF to read transient data | hemmt | Fluent UDF and Scheme Programming | 0 | January 11, 2017 01:51 |
UDF DPM_BC with F_UDMI not storing data | balki | Fluent UDF and Scheme Programming | 3 | June 6, 2016 23:10 |
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 10:46 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
UDF to read and write data | Mcgregor | FLUENT | 4 | June 9, 2003 14:21 |
