Define Mixture properties in UDF
Old   November 6, 2019, 11:10
Post Define Mixture properties in UDF
Miketsap
miketsap is on a distinguished road
I have a piston and inside there is a mixture(liquid A & B) of a compressible liquid.
In the pistons there is a hole but ONLY the liquid A can flow through. As a result the density of mixture in liquid A is getting lower.
Also I have the mixture density as an equation of PressureA and PressureB.
Do you know how I can define the density as percentage of A and B?
I need the percentage of liquid A and Liquid B in the volume each time so Density= 0.3PressureA + 0.7 pressureB if it's 30%LiqA and 70%liqB.
Please help me, thank you
miketsap is offline   Reply With Quote
define density, density, liquid, mixture and liquid, udf
SR_Rate UDF For a MEMs model timjm Fluent UDF and Scheme Programming 1 October 10, 2018 03:16
Is it possible to define properties of mixture in Mixture model? AllenZHANG Fluent Multiphase 0 June 21, 2018 10:11
UDF compiling problem epc1 Fluent UDF and Scheme Programming 0 September 25, 2012 20:36
UDF problem libia87 Fluent UDF and Scheme Programming 1 May 4, 2012 22:49
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
