Angular velocity in fluent UDF
Old   October 31, 2019, 05:16
Default Angular velocity in fluent UDF
gh
gh_100 is on a distinguished road
Hello everyone,I'm using fluent UDF to define angular velocity for dynamic grid simulation, and the angular velocity was set 5ras/s,but the result of fluent calculation is different from what I defined.
for example,the angular velocity was 5ras/s,the time to calculate one circle should be 2*pi/5=1.25s.But I calculated for a long time (such as 20s) and didn't reach a circle(2*pi).
the code is below:
DEFINE_CG_MOTION(side2,dt,vel,omega,time,dtime)
real flow_time = CURRENT_TIME;
if(flow_time >=0)
omega[2]=-5;
does anyone can help me?
Thank you in advance
gh_100 is offline   Reply With Quote
Old   November 1, 2019, 00:17
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what about
omega[2]=-5;
how it works?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 1, 2019, 02:17
gh
Originally Posted by AlexanderZ View Post
what about
omega[2]=-5;
how it works?
hello AlexanderZ
the omega[2] represents rotation around the Z axis, with a size of 5 radians / s.
thank you .
Old   November 1, 2019, 03:53
Alexander
check if it works or not
best regards
angular velocity udf 2*pi
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 03:48
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
(UDF) Sinusoidal inlet velocity in Fluent star Fluent UDF and Scheme Programming 1 December 19, 2013 17:23
