UDF for moving a solid 3mm in -x direction
Old   October 25, 2019, 10:43
Lightbulb UDF for moving a solid 3mm in -x direction
Andy
abeldar is on a distinguished road
I am new to UDFs.
I am working on a torque converter. I want to apply the torque converter clutch. For that, I need to move the friction plate 3mm.
I tried using 1DOF translational but I cannot stop it after traveling 3mm.
So now, I am planning to use 6 DOF.
Also, what macro is there to stop the displacement after a certain distance?
I could not find it.
Thank you for your time.
abeldar is offline   Reply With Quote
Old   October 28, 2019, 02:32
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
change velocity to 0 after 3mm
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
1dof, translational motion, udf
UDF: problem with calculating velocity gradient to normal direction hkdai Fluent UDF and Scheme Programming 0 January 15, 2019 03:29
udf for moving a zone in one direction mehdiaa FLUENT 0 August 8, 2017 09:05
Fluid turns into solid at given T (via viscosity UDF or solidifcation model?) jpina FLUENT 1 April 3, 2016 04:48
UDF for solid volume of fraction Capricorn Fluent UDF and Scheme Programming 0 March 22, 2016 05:06
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
