What's wrong with my UDF?
Old   September 8, 2019, 23:39
Question What's wrong with my UDF?
刘宵
Jonathon_L is on a distinguished road
Hi all,
This is my code and I'm trying to calculate the value of w by UDF. The value of w is related to the angle at which the fluid impacts the wall. So I loop through the cells first, then loop the faces inside the cells. Finally, I hope that I can save the value of w to the data so that I can see the distribution of w from the contour. But my UDF doesn't work, I don't know what' wrong with it.
Thanks very much if you can give me some suggestions.
#include "udf.h"
#include "math.h"
#include "metric.h"
#include "mem.h"
DEFINE_ON_DEMAND(on_demand_w)
real w;
int n;
real densic=3200;
real c;
real alpha;
real A[ND_ND];
real vel[3];
real velm;
real Am;
real cos;
real velx;
real vely;
real velz;
real qm;
Domain *d;
Thread *t;
cell_t c0;
face_t f;
d=Get_Domain(1);
c=sqrt(3*480*1000000/densic);
thread_loop_c(t,d)
c0=F_C0(f,t);
begin_c_loop(c0,t)
real denmix=C_R(c0,t);
c_face_loop(c0,t,n)
velx=F_U(f,t);
vely=F_V(f,t);
velz=F_W(f,t);
vel[1]=velx;
vel[2]=vely;
vel[3]=velz;
qm=velx*denmix*3.1416*0.0045*0.0045;
F_AREA(A,f,t);
velm=NV_MAG(vel);
Am=NV_MAG(A);
cos=NV_DOT(vel,A)/velm/Am;
alpha=asin(cos)*180/3.1416;
w=7/3.1416*qm/denmix*pow((velm/c),2.5)*sin(2*alpha)*sin(alpha);
C_UDMI(c0,t,0)=w;
fprintf("out_w:%g\n",w);
end_c_loop(c0,t)
Jonathon_L is offline   Reply With Quote
Old   September 9, 2019, 16:41
pakk will become famous soon enough
#include "udf.h"
#include "math.h"
#include "metric.h"
#include "mem.h"
 real w;
 int n;
 real densic=3200;
 real c;
 real alpha;
 real A[ND_ND];
 real vel[3];
 real velm;
 real Am;
 real cos;
 real velx;
 real vely;
 real velz;
 real qm;
 Domain *d;
 Thread *t;
 cell_t c0;
 face_t f;
 d=Get_Domain(1);
 thread_loop_c(t,d)
  c0=F_C0(f,t);
  .. (rest of code removed because the first problem is here)
You ask Fluent to use f, but you never tell Fluent what f is. Yes, you declare it as a face, but Fluent has no idea which face you mean.
I cannot really figure out what you are trying to do, but probably you forgot to loop over all faces or something like that.
Your compiler should have complained that something is wrong in this line. Always check compiler errors, especially if you have a problem with compiling!
pakk is offline   Reply With Quote
Old   September 9, 2019, 16:47
And some suggestions to improve your code:
You should have declared this variable higher up, at least in the default dialect of c that Fluent uses.
velx=F_U(f,t);
vely=F_V(f,t);
velz=F_W(f,t);
vel[1]=velx;
vel[2]=vely;
vel[3]=velz;
This is not very useful, just simplify it to:
	        vel[1]=F_U(f,t);
                vel[2]=F_V(f,t);
                vel[3]=F_W(f,t);
Your alpha is in degrees, but sin expects an angle in radians. Don't convert, just keep it as it is:
                alpha=asin(cos);
Old   September 9, 2019, 22:09
刘宵
Thank you for your reply, and I'll try.
udf code
can anyone help me about the udf of dynamic contact angle in FLUENT? Albert Lee FLUENT 0 July 1, 2018 09:21
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
whats wrong with this udf ? h.mortezaee Fluent UDF and Scheme Programming 3 September 14, 2015 08:32
something wrong when compiling udf, however the code is correct when interpreting richard ben Fluent UDF and Scheme Programming 7 May 11, 2013 08:36
what's wrong with the UDF major FLUENT 6 March 3, 2005 07:39
