September 8, 2019, 08:56 |
UDF for Time Dependent Heat Flux
Mustafa Abba Imam
Rep Power: 7 |
Hello Everyone
I am a beginner of Ansys Fluent, working on Concentrated Solar Power My model comprises an array of reflectors focusing solar radiation onto an Absorber Tube. Inside the tube is a working fluid which is expected to be heated by the Heat Flux impinging on the surface of the Absorber Tube. I want to use Fluent to determine the flow, heat transfer and heating of Heat Transfer Fluid. However, my Heat Flux varies with time, 7am to 7pm. Please can anyone guide me on how to develop a UDF code for a time-dependent Heat Flux Thank you Below is time-dependent Heat Flux (W/m-2) 7 806 8 891 9 957 10 968 11 969 12 963 13 936 14 875 15 794 16 695 17 519 18 14 19 0 |
September 23, 2019, 04:09 |
Alexander
Rep Power: 34 |
for your simple case you may use this approach:
https://www.youtube.com/watch?v=s_YkmvFH8VQ best regards |
UDF for a time varying heat flux boundary condition | B.Hamada | Fluent UDF and Scheme Programming | 9 | August 8, 2018 13:51 |
Doubt - Variable Heat Flux input - UDF | Neethu_N | FLUENT | 1 | December 19, 2017 12:48 |
UDF for mass and heat source with heat transfer | rajendra1 | Fluent UDF and Scheme Programming | 35 | October 13, 2017 05:04 |
Problem in UDF time dependent vloumetric heat source | eng_yasser_2020 | Fluent UDF and Scheme Programming | 0 | March 30, 2014 09:07 |
Space- and time-dependant heat flux via UDF | flotus1 | Fluent UDF and Scheme Programming | 4 | September 10, 2012 09:00 |
