August 7, 2019, 07:27 |
Error compiling UDF in Fluent
Rep Power: 7 |
I am trying to compile the udf of motion. But error pops up each time. It shows
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).\n\nThe system cannot find the file specified. \n\nD:\Flapping Wing Simulations\moving mesh Piezofan simulation\Test1\MMPiezoFan_files\dp0\FFF\Fluent\l ibudf\win64\3ddp_host\libudf.dll Error Object: #f #include "udf.h" DEFINE_CG_MOTION (rotational_motion, dt, cg_vel, cg omega, time, dtime) { Domain *d =Get Domain(1); Thread *t_object = Lookup_Thread(d, 2); real moment [ND_ND], cg[ND_ND], force [ND_ND]; Compute_Force_And_Moment(d, t_object, cg, force, moment, TRUE) real moment_z= moment [3]; \* To compute the moment at the beginning of the time step and feed into the equation of motion */ real i1 = exp(-0.823*time); real i2 = cos (8.19*time); real i3 = 48870 sin(8.19*time); real i4 = 2.893 pow(10,-8); real omega = -i4 * moment_z * i1 * (i2-i3); cg_vel[0]=0.0; cg_vel [1]=0.0; cg_ve1[2]=0.0; cg omega [0]-0.0 ; cg omega (1)-0.0; cg omega [2]=real omega; } Fluent version is 18.2 and VS 2015. Please help! |
August 19, 2019, 08:41 |
Sebi
Rep Power: 7 |
I assume you have setup your cimputer with VisualStudio as a compiler and can compile other UDF's.
It looks like in your definitions "cg omega" has a space which is probably causes issues with it reading it as two variables or expecting a ',' or ':' . |
August 20, 2019, 01:41 |
Alexander
Rep Power: 34 |
open VS console, run fluent, compile
best regards |
Problem running fluent with udf on batch | tobi b. | Fluent UDF and Scheme Programming | 3 | April 14, 2016 14:54 |
implementing UDF for fluent in workbench for running multiple simulations | faizan_habib7 | Fluent UDF and Scheme Programming | 0 | March 18, 2016 23:29 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 11:16 |
UDF problem caused by various version of Fluent | Yurong | FLUENT | 3 | January 15, 2006 11:57 |
